d15b pre swap info
Old Aug 8, 2009 | 09:02 AM
misha's Avatar
Default d15b pre swap info
Im thinking to to convert to obd1 and go with d15b in my 91 mpfi DX
Just want to gather my thoughts together to make sure i understand what all i need to make this thing run.
1. Repin my, mpfi converted, obd-0 to obd-1 like so:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/non-obd-obd1-conversion-gold-ef-1510399/
and plug in a p28
2. Cut the resistor box out with all the wires joined and run obd-1 injectors
3. Motor will be direct bolt in with my zc tranny
IS that it?
1. Do i need a different driverside engine mount?
2. Anything to change around with distributor or any plugs for that matter?
3. how many plugs will be different?
4. Anything else im missing? I need this to be as easy as possible since i dont have much more time to screw around.
5. And what do i do about the o2 sensor
Old Aug 8, 2009 | 12:56 PM
BiG ChOr!Zo's Avatar
Default Re: d15b pre swap info
Off topic i pm you a couple weeks ago about a question and never heard back...que pasa...!!!
Old Aug 8, 2009 | 01:16 PM
Clipsed's Avatar
going to need to run an obd1 dizzy, which has different plugs. You could snip off plugs from an obd 0 dizzy, and plugs from an obd 1 engine harness, and make an adapter harness for your dizzy. As for the o2 sensor, obd 1 has a 4 wire o2, while obd 0 is a one wire, so you will need to run those new wires to the ecu.
Old Aug 8, 2009 | 03:36 PM
misha's Avatar
wil i need to switch dizzy wires around tho? I can always make a plug out of anything, as long as i got the right wire order, but where do i get that?
And i think d15b had one wire o2, so thats confusing as well, i guess if i add a 4 wire o2 at least 3 new wires will run into ECU, which wires are those and where do i find it?
BIG: pm me again i was out of the country
90civicstdgold
Jul 7, 2011 03:20 PM
tazz29
Feb 20, 2009 10:42 AM
^Sammy]!.
Sep 12, 2006 11:07 AM
redlseg
Aug 7, 2005 08:20 PM
