NEED HELP: 91 INTEGRA MY AXLES KEEP COMING LOOSE
BUMP IF VIEWED, I NEED ALL THE HELP I CAN GET
OK GUYS, I HAVE A 91 INTEGRA GS WITH B20B / S1 B16 TRANNY. I"M NOT SURE WHY MY DRIVER SIDE AXLES KEEP COMING LOOSE. ANYBODY KNOW WHICH AXLES I SHOULD GET TO FIX THIS PROBLEM? WHAT CAR AND YEAR AXLES SHOULD I GET? RIGHT NOW THE AXLES ITS RIPPED AND CAME PRETTY MUCH LOOSE. THIS IS MY 2ND AXLES THAT CAME LOOSE AGAIN, SO ANYBODY HAVE ANY IDEA, PLEASE COMMENT BACK. THANK YOU FOR READING
what axles are you using? ... autozone is usually the cause of this problem, but without knowing wht axles you are using, there is no telling what your problem is.
most likely your axle is not popping all the way in..make sure you have the clip thats on the end of the axle and thats not all close..thats the clip that makes the axle stays lock in place
Make sure the clip is on the axle and I always make sure the clip is facing down (open end down) and they usually snap right into place.
I think i found the problem, i think its the autozone axles. Its probably too short, maybe thats why it keep coming loose. Where can i find or get a 92-93 gsr axles?
