Car will shift into gear, but will not move?
Old Aug 7, 2009 | 10:43 PM
CRISIS's Avatar
Default Car will shift into gear, but will not move?
My fiance just bought a 1991 Honda Accord Ex, Auto transmission, 195k and it was having a problem moving the shifter into any gear. It took a lot of muscle to get it into any gear, but the transmission showed no adverse effects.
Now the car will not move no matter what gear it is put in, Reverse, Drive, D3, D2, D1 none of them work. She can put the car in Neutral and push the car.
Thought this was the end of the problem. It gets worse.
Now she can not even get it back into Park or Reverse. She has to leave it in Neutral with the e-brake up.
I've searched and am hoping it is either the transmission fluid (too low) or the brake switch/solenoid is bad.
Any advice?
Old Aug 8, 2009 | 05:19 AM
kccord's Avatar
Default Re: Car will shift into gear, but will not move?
Sounds like the clutch plates from the auto tranny gave off, time to replace it.
Old Aug 9, 2009 | 01:09 AM
YeuEmMaiMai's Avatar
fluid level?
is the selector cable binding
is the interlock working properly?
Old Aug 10, 2009 | 01:01 PM
607Honda21's Avatar
New User
you think maybe the throw out barring is maybe bad not familiar with autos. not even sure it has one but my buddys civic did the same and his was the throw out, but check first and see if autos have one. could be the problem.
Old Aug 14, 2009 | 02:39 PM
CRISIS's Avatar
Well, the car is off to the mechanic. Her cousin said she would give back the money for the car because it's just a bad situation.
If I ever find out what the problem was, i'll edit my post for future searcers.
yingvang31
Apr 6, 2015 10:28 PM
mk818
Aug 27, 2012 08:37 AM
dsowers19
Mar 19, 2012 12:04 PM
AzntstyleZ
Jun 27, 2005 08:21 AM
DrZaius
Apr 24, 2005 06:53 PM
