MI 1997 EK HATCH 6K Miles Big Titties!!!
READ THIS FIRST!
ANY QUESTIONS YOU ASK THAT ARE ANSWERED HERE, WILL BE IGNORED! READ IT!
This car was a dream come true for me, I just happen to do it about 10 years late.
This is the car I wanted to build in 1996 when I was a single dude, partying all the time and rampaging random towns in SE Michigan with out a care in the world.
Now Im 31 years old, Married and have two children. On the up side, I make enough money now to have actually built a car this sweet. On the down side, its just not a practical car for a family man.
So to put it plain and simple, I need a car I can drive all year round and actually put my family in and go somewhere.
Only having a CRV we can all go out in kinda sucks and if anything ever happened to the CRV, My wife and kids would be stuck with no vehicle thats practical to move about in.
Now. Onto the car.
Everything is NEW/OEM unless stated otherwise, I wont state the obvious.
Everything was purchased and installed within the past 6 months, and has only seen the mileage that's on the motor right now.
1997 Honda Civic CX Hatchback:
VIN# 2HGEJ6442VH100446
CarFax reports a discrepancy in chassis mileage reported from 3rd owner, Last known chassis mileage was over 200,000 miles.
Engine Mileage: 11,630 Miles as of 10/16/09
Title: Clean
Exterior:
Paint Code: 07' Chrsyler PRN Red (Dodge Viper/Charger) Painted in mid 2008.
Waxed on a monthly basis.
Civic Type R Head lights.
(non-oem) Civic Type R Tail lights and weather seals.
Matte Black Buddy Club P1 Racing Wheels (Imported directly from Buddy Club Japan)
Buddy Club Wheel Lock Lug Nuts
Yokohama S. Drive Tires 195/50/15
Hatchback weather seal.
Spoiler weather seal.
Driver and passenger door outer window seals.
Windsheild Seal.
Front Bumper splash guard.
All glass is OEM except passenger rear window and windsheild.
Engine Compartment:
Sec 1; Block
B18B1 Block, Hot tanked and bored over to 81.5mm
B18B1 Crankshaft, Hot tanked and micropolished.
Honda OEM Bottom End Kit (All seals and gaskets)
ACL Race, Main and Rod Bearing's & Thrust Washer
Shotpeened and Honed PR4 Connecting Rods
ARP Rod Bolts
RS Machine 10:6:1, 81.5mm Pistons (Oversize B16A)
Hastings Rings
LS Oil Pan (used)
Blox Magnetic Oil Drain Plug
Golden Eagle LS/VTEC Conversion Kit
LS Head Gasket
ITR Water pump
ITR Oil Pump
OEM Harmonic Balancer/Pulley (used)
Balanced Rotating Assembly
Sec. 2; Head
VIN# Unknown (Purchased with vehicle)
B16A2 VTEC Head, Hot tanked and fully rebuilt.
Milled 10 thousanths to ensure flatness and raise compression.
Supertech Dual Valve Springs & Titanium Retainers.
ARP Head Studs
Valve Guides
Valve Seals
3 Angle valve job
Civic Type R Cams
B16A2 Distributor (Yes New)
Skunk 2 Adjustable cam gears
Honda OEM Top End Kit. (All seals, gaskets & nuts)
Golden Eagle triple O ring cam seal
Powder Coated Valve Cover
VTEC Solenoid Gasket
Mild Port Job
Sec. 3; Bolt Ons, Sensors & Misc.
130 Amp Alternator
Skunk 2 Pro Series Intake Manifold
Hondata Intake Manifold Gasket
LS fuel Rail (used)
RC 310cc Fuel Injectors
Blox Fuel Pressure Gauge
Blox Fuel Pressure Regulator
Blox 66mm Throttlebody
Blox TPS Sensor
MAP Sensor
AEM Short Ram Air Intake
Fuel Filter
Comptech 4-2-1 Ceramic coated header
Magnecor Competition Spark Plug Wires
NGK BKR7E Spark Plugs (Maybe moving to 6)
Timing Belt
Alternator Belt (non-oem)
AEM UEGO Wideband Oxygen Sensor
Bosch Primary Oxygen Sensor
Primary Coolant Hoses
Radiator
Thermostat
Mugen Oil Cap
Duralast Battery
Front Radiator Core Support
Scuffed,Primed and Shot with Single Stage Paint
Sec. 4; Engine Wiring
All Engine/Transmission to Chassis grounds upgraded to 4 gauge
0 Gauge Battery Ground
Battery to Fuse Box upgraded to 4 gauge
Starter upgraded to 4 gauge
Alternator upgraded to 4 gauge
Complete Engine harness re-wrap and re-loom.
OBD2A to OBD1 Conversion Harness
VTEC Sub Harness pinned directly to OBD1
Street Wires Fused Positive Battery Terminal
Street Wires Negative Battery Terminal
Sec. 5; Transmission
VIN# Unknown (Removed)
Purchased from Beasley Foreign Auto Salvage. 12/16/08 Holly,MI
S4C Transmission (B16A2)
Appox. 90,000 Miles.
Clutch
Throwout Bearing
Lower Transmission Mount
No Slips,Grinds or Problems.
Suspension & Underbody:
Koni Sport Yellow's
Ground Control Adjustable Coilover's
Blox Rear Control Arm's
Blox Front Upper Control Arm's with Adjustable Ball Joints
S Type Straight Pipe
2 1/2" Exhaust
Exhaust Hangers
Shift Linkage Bushings
Interior:
Sec.1; Mechanical & Non-Mechanical
Heater Core
Full Interior Dynamat
AC components Completely removed
Civic EX door's swap (Added power locks and windows) Previous owner
Blox Cluster Pod
99 Civic Si Gauge Cluster
Autometer Oil Pressure Gauge
Momo Steering Hub & Quick Release
No Name 320mm Steering Wheel
Black Carpet
Black Floor mats
99 Honda Prelude Front Seats
98 Civic Type R Rear Seats (PasswordJDM)
Hatchback Black Carpet
99 Civic Si Full Center Console
Civic Type R Shift Boot
No Name Shift ****
Sec.2; Electronics
Sec. 2.1 Car Audio & Video
Pioneer Premier DEH-P780MP In Dash Car Stereo with Remote
Infinity Kappa 6.5" Front Door Speakers
Infinity Kappa Door Tweeters & Hi Frequency Crossovers
Infinity Kappa 6x9 Rear Speakers
Kenwood KDC-3011W 12" Subwoofers
Orion 2150sx two channel subwoofer amplifier
Diamond Audio D300.4 Four channel mid and hi range amplifier
Street Wires 0 Gauge Wire Amplifier Kit
Single 0 Gauge to dual 4 Gauge splitter/fuse block
All Speakers wired with 10 gauge speaker wire
Fully Tuned Crossovers
Hanns-G 8" Touch Screen/TV/Computer Monitor with Remote
Power Inverter with two plugs and one USB power plug
Sony VAIO Laptop Computer Wired Directly to Head Unit AUX Input For iTunes Playback,Located in glovebox. (Also see Sec. 2.2)
Head Unit Noise Filter (Eliminates alternator whine)
Sec. 2.2 Engine Management & Tuning
OBD1 P72 ECU (Integra GS-R)
Hondata S300. Wired directly to laptop computer and touch screen for real time engine management.
AEM UEGO Air/Fuel Ratio Gauge
Tuned by Tony @ Speed Industry on Mustang Dyno 6/21/09 (www.SpeedIndustry.Biz)
Sec. 3 Security
Viper alarm system with keyless entry
Some other things have been done to ensure the security of this car that will only be disclosed to the new owner.
New Engine Break in Procedure:
I wanted to tell any potential buyers the process that was used for break in of this motor.
93 Octane fuel from first startup.
Oil Change Regimen
0 - 20 Miles SAE 30W Non-Detergent Motor Oil & OEM Honda Oil Filter.
I did alot of short blast's in this period and instead of using my breaks to slow down I allowed to motor to decelerate on its own.
No VTEC during this period.
20 -100 Miles SAE 30W Non-Detergent Motor Oil & OEM Honda Oil Filter.
This period I was doing hard pulls, Using VTEC and redlining at 7k
Compression test on all 4 cylinders read. 210,208,210,209.
I still would not cruise at a steady speed alternating engine speed as much as possible.
100 - 500 Miles 10w30 Mobile Non-Synthetic Motor Oil & OEM Honda Oil Filter.
I started driving the car more normally late in this period but still never keeping a steady cruising speed.
And still no highway driving at this point. Compression test at 500 miles read 210 across all four cylinders.
500 - 1000 Miles 10w30 Mobile Non-Synthetic Motor Oil & OEM Honda Oil Filter. At this point I was driving much more normal.
Not using VTEC very often and started using the highway and cruising around 900 Miles.
1000 - 2000 Miles 10w30 Mobile1 Synthetic Motor Oil & Mobile1 Oil Filter. Compression test read 210 across all cylinders again.
At this point break in is complete and the rings have seated properly in all four cylinders.
2000 - 5000 Miles 10w30 Mobile1 Synthetic Motor Oil & Mobile1 Oil Filter.
Price,Location & Contact Info
Im asking 8,000 or Best Offer for this car. Im located in Lake Orion, Michigan. I can be reached by Phone or by Email and my name is Joe.
248-238-2743 or JoeStrange@Comcast.net
All of my pictures are located here in HI RES:
http://s836.photobucket.com/albums/z...oeStrange4958/
Trades are welcome, Im looking for something that's Quick,Reliable and could be considered family oriented. So im looking for an 02' and up WRX or WRX Wagon.
Now. Onto the car.
Title: Clean
Exterior:
Windsheild Seal.
Engine Compartment:
Sec 1; Block
ARP Rod Bolts
Hastings Rings
LS Oil Pan (used)
LS Head Gasket
ITR Water pump
ITR Oil Pump
Sec. 2; Head
ARP Head Studs
Valve Guides
Valve Seals
3 Angle valve job
Civic Type R Cams
Mild Port Job
130 Amp Alternator
LS fuel Rail (used)
Blox TPS Sensor
MAP Sensor
Fuel Filter
Timing Belt
Radiator
Thermostat
Mugen Oil Cap
Duralast Battery
Clutch
Throwout Bearing
Koni Sport Yellow's
2 1/2" Exhaust
Exhaust Hangers
Interior:
Heater Core
Blox Cluster Pod
Black Carpet
Black Floor mats
No Name Shift ****
Sec.2; Electronics
Sec. 3 Security
Oil Change Regimen
