HELP: Car hesitates between 3000-5000RPM once warmed up
Old Aug 7, 2009 | 09:51 PM
jspec_dc4's Avatar
Icon3 HELP: Car hesitates between 3000-5000RPM once warmed up
So i just swapped my Integra RS B18B for a JDM B18C1. When the car is cold and temp gauge is bellow 3/10 then the engine runs amazingly. Once it creeps over that mark the car will sporadically hesitate almost as if somone put a sock inside the intake.
SYMPTOMS:
-Car will sporadically loose power between the RPMS of 2500(3000) to about 5000, after which most of not all power is restored and the car pulls HARD!
-Only occurs when car reaches normal opp temp, if its not fully warmed up the car pulls great!
-No engine codes, fresh oil, full coolant, .etc
Cure:
Thanks guys!
Old Aug 8, 2009 | 05:18 AM
95 integra's Avatar
Default Re: Car hesitates between 2500-5000RPM once warmed up
I have a very similar problem, I'm thinking its a bad temp sensor somewhere. I "had" a stock P28 in mine that I thought was causing the issue, but it's since been replaced w/ a chipped gsr ecu (with stock gsr map) and it still does it. I actually need to go out there and play around with that....
Old Aug 8, 2009 | 07:59 AM
jspec_dc4's Avatar
i have heard fuel filter, fuel pump, bad dizzy/wires, .etc
except i prefer not to go and change everything in my car to find out what this is.
Old Aug 8, 2009 | 11:36 PM
jspec_dc4's Avatar
nobody?
Old Aug 9, 2009 | 08:48 PM
jspec_dc4's Avatar
Default Re: HELP: Car hesitates between 3000-5000RPM once warmed up
c'mon honda-tech, where are the gurus?
Old Aug 9, 2009 | 09:18 PM
HGZ's Avatar
HGZ
check the rotor in your distributor. my car used to hesitate after it was warm and seemed to only do it between a certain RPM range or when i tried to accelerate pretty hard from a stop.
i replaced the spark plugs, changed the fuel filter, replaced the o2 sensor, still hesitated. but when i finally decided to take a look in the distributor my rotor was all mangled to **** and the screw holding it in was just bouncin around not doing its job! i couldn't believe it. so yeah i replaced the rotor and the hesitating completely went away.
the rotor might not be your problem, but i would check it out anyway since its free and doesn't take long to do.
Old Aug 9, 2009 | 09:30 PM
jspec_dc4's Avatar
This one is not too bad, this one is actually from my buddies EG6 because mine died on me. So i borrowed his and when it came back to putting it on his car, his car ran like garbage so i kept it. Now i owe him one and this rotor's screw is stripped on..
Old Aug 9, 2009 | 10:12 PM
HGZ's Avatar
HGZ
ouch! dang well i guess we know its not going anywhere and if it does, sweet it came out on its own
Old Aug 10, 2009 | 01:45 PM
jspec_dc4's Avatar
Yeh ill see, maybe someone i know has that stripped screw remover kit. If so ill buy a new rotor and cap and see what happens.
Old Aug 11, 2009 | 03:02 PM
jspec_dc4's Avatar
changed plugs just to have fresh ones and that didnt change anything.
May buy new rotor and cap soon or may just send her to Acura.
Old Aug 11, 2009 | 03:58 PM
Daniel jdm's Avatar
bump...
Old Aug 12, 2009 | 05:20 PM
jspec_dc4's Avatar
thanks dude ^^^
i hope this gets done soon dammit! I may be buying a dizzy to swap in and see what happens.
Old Aug 21, 2009 | 02:32 PM
jspec_dc4's Avatar
took it to acura, and they cannot point anything out.
They pretty much said, oh you have aftermarket plugs and wires, maybe change those...
UHH? Thanks
accell wires and NGK plugs wtf? so put some OEM wires on, no diff..
Old Nov 25, 2011 | 12:36 AM
Hilt37Vtec's Avatar
i know this is old but if you ever found what was wrong let me know my car is doing the exact same thing..
skylerreniger
Apr 30, 2013 12:24 PM
GRANT!
Apr 27, 2010 08:14 AM
B18CmeFLYby
Mar 1, 2008 01:51 PM
onyx00
Dec 2, 2005 08:22 AM
