need help for tranny install
ok, i'm trying to remount the transmission onto my engine. the clutch is lined up correctly but the transmission just will not slide onto the engine. I can get it to about 1/2" away from the engine, BUT it just stops and will not slide any farther. i've checked for clearance issues and everything seems to be fine. I've been able to get 1 bolt in at a time, but the others absolutely will not go in because i'm unable to get the tranny any closer. Does ANYONE have any ideas/or know why it's not remounting? Thanks.
Del
Del
on your transmission you will have dowel pins, i know my h23a has 2 of them. they will slide into the side of your block and once you have them properly inserted into the block your tranny will bolt right on. here is a picture of the side of my block, i THINK these are the holes the dowel pins go in, i cant remember so i MIGHT be wrong, they should be the holes that are not threaded. once you look at the tranny youll see what im talking about.
remember, its a lot easier to do with 2 people instead of one...
[Modified by GudeH23a, 2:35 AM 8/25/2002]
Sam92Teg
Aug 14, 2005 08:05 PM
ridestrt
17
Aug 29, 2003 11:17 AM
