Are 98R headunits different than 00-01's
Old Aug 7, 2009 | 09:39 PM
RGoose18's Avatar
Default Are 98R headunits different than 00-01's
I believe the pin connector on the 00-01's is different than the 98's. My 98 looks like the picture below. The reason why I ask is because I bought a DICE ipod kit for 98-01's, although it doesn't fit because it seems honda changed the pin connection after 98. Any input on this issue is greatly appreciated. Spending $140.00 and having DICE repeatedly state it'll fit, and it doesn't, truly sucks.
Here is the DICE ad that shows the "98-01" kit
http://www.diceelectronics.com/Merch...ICE_IPOD_HONDA
Old Aug 7, 2009 | 09:44 PM
Steady R's Avatar
Default Re: Are 98R headunits different than 00-01's
they should all be the same
as far as i know the only different ones are 99-00 civic si's. there connectors are square.
fyi
my 01 itr is using a tape deck from a 91 accord
Old Aug 7, 2009 | 09:45 PM
RGoose18's Avatar
fyi
I thought so too, but check out this link to DICE's 98-01 kit. It's alot different from my 98'
Old Aug 8, 2009 | 02:28 AM
BlueIntegraBoy's Avatar
I have a similar IPOD kit using it on my JDM 98 spec R headunit. It is for the newer plug (the white far left) on the radio. I think you are out of luck.
Old Aug 10, 2009 | 09:54 AM
Tekkaboy's Avatar
If it doesn't do what they advertise, I'd just return it.
If it's not plug and play but you still want to use it, you can always cut the wires from the DICE harness and join them to the corresponding wires on the OEM harness.
stocklxcivic
Feb 15, 2008 08:32 AM
antintegra
Feb 13, 2006 05:11 AM
fastbrakes
Dec 10, 2002 02:32 PM
Pineapple Devil
Nov 8, 2002 06:31 PM
