Need help w/ a DICE ipod kit (DC2 headunit)
So I bought a DICE ipod integration kit (model R2) to go w/ my 98 integra headunit. There website clearly states that it's a standard fit.
Now after receiving my dice kit, I come to find out that the 98 integra headunit is different than the 99-01's and the plugs don't fit. I called dice and they were absolutely no help.
1) Has anyone run into this before???
2) Can I cut the stock wiring harness, wire in the 99-01 harness and purchase a cheap stock 99-01 headunit off ebay?
Any help is appreciated
Pictured below is a 98 Integra Headunit
Here is the Dice ad that shows the "98-01" kit
http://www.diceelectronics.com/Merch...ICE_IPOD_HONDA
You could wire in a 99-01 HU if you want to use that ipod kit, yes. Ideally, use a forward harness and a reverse harness 70-1720 & 71-1721 iirc.
Do I simply splice the 2 kits together? Or do the male and female ends match up so I don't have to strip, splice, and solder
sircivic902
11
Nov 14, 2010 02:20 PM
Built B16A
Audio / Security / Video
Nov 2, 2008 07:50 AM
donteatmeet
Feb 27, 2005 08:19 AM
