need help with b20 swap into a 92 civic hatch
Old Aug 7, 2009 | 09:22 PM
2fastss's Avatar
Default need help with b20 swap into a 92 civic hatch
Whats up guys, this is my first honda and my first hatch...the car used to have a gsr motor in it and we took it out and swapped over a jdm b20 that I picked up from JEI in sterling Va...
the motor that I picked up had no wiring harness so I had to swap over my gsr wiring harness making me switch over the dizzy that was on my gsr and same thing with the alternator...
Now the problem is the throttle cable was cut on the b20 that I picked up so I was left with the only option which was to reuse my b18 throttle cable, which makes it not fit the b20 bracket....
What do you all suggest? Get a b20 throttle cable so it will fit that stock b20 bracket or mock up a bracket to fit the the b18 throttle cable??
Old Aug 7, 2009 | 09:53 PM
slowhatchcali's Avatar
Default Re: need help with b20 swap into a 92 civic hatch
you can make a throttle bracket or you can get a LS throttle cable and LS throttle bracket..
Old Aug 7, 2009 | 09:54 PM
96DelSol's Avatar
get a b20 tb cable
Old Aug 7, 2009 | 10:37 PM
Lambo123's Avatar
ha thats funny ive never heard anyone mention this before. i mocked up a bracket from a piece of scrap metal lying around. its probably the ugliest thing in my engine bay. but it works.
Old Aug 7, 2009 | 10:55 PM
2fastss's Avatar
ok ls throthle cable and a ls bracket from what exactly?? what year so forth... Im still new to all this honda stuff haha
Old Aug 7, 2009 | 11:44 PM
from a 94-01 integra.. just make sure its LS, the bracket should have a "P75" stamped on it
byc_cb7
Apr 3, 2012 09:08 AM
jesusjdm69
Mar 31, 2009 05:32 AM
djmatix
May 19, 2007 02:00 PM
