CEL Problem
Old Aug 7, 2009 | 05:50 PM
EG6JUNK's Avatar
Default CEL Problem
when i start the car, cel blinks normal, but when i drive it on the freeway or reach a certain speed or rpm CEL stays on, till i turn off the car, any suggestions what it could be? car has a jdm b16 swap on the car. lmk thanks
another question: i turn on my cd player on the car, and i dont hear any sound coming out of my speakers, just a low staticly type sound. i dont think its blown because i can still hear out of it? any suggestions would help thanks
Old Aug 7, 2009 | 06:16 PM
EG6JUNK's Avatar
Default Re: CEL Problem
i tried using the pin code on the passenger side, with a paperclip, but the CEL stays on and does not blink
Old Aug 7, 2009 | 11:22 PM
Former User's Avatar
When the CEL turns on while driving, pull over and leave the engine running while you jump the service connector. You should be able to pull the code this way.
Old Aug 7, 2009 | 11:49 PM
EG6JUNK's Avatar
so when it goes on, jump the connector while the engine is on correct? alright ill give this a shot. any suggestions about the speakers? thanks
Old Aug 8, 2009 | 06:10 AM
Yes
Do the speakers work when the radio is on? If so, the cd player is likely the problem.
Old Aug 8, 2009 | 09:13 AM
EG6JUNK's Avatar
the speakers, just have a staticy sound, you can only hear it when the volume is on high though.
Old Aug 8, 2009 | 07:44 PM
EG6JUNK's Avatar
ok cel code is #23 knock sensor, where is it located on the engine and how to fix it? thanks
b20vtech
19
Feb 6, 2009 08:21 AM
ls19integra95
Feb 26, 2008 07:16 PM
lilpastrana
Feb 27, 2007 04:59 PM
CompanyFlow
Acura TL, RL & ZDX
Oct 26, 2006 08:24 AM
silvervtecrx
Oct 10, 2004 07:30 PM
