JDM 97 B16a SiR-II OBD 2 Into EM1 Question
Old Aug 7, 2009 | 03:14 PM
eM1<3's Avatar
Icon3 JDM 97 B16a SiR-II OBD 2 Into EM1 Question
As the title says, i'm putting an OBD2 97 B16a SiR-II into my EM1
Now that I know it's an OBD2, Do I HAVE to switch over these things as following? Even though my car is an OBD2 also?
Vtec solenoid
Intake manifold
Distributor
alternator
Oil pump
This is originally what I would have to switch over if the engine were an OBD1.
Do I still apply to these things to my engine, even though it's a JDM OBD2?
Or would It be a direct drop in like i'm hoping?
Old Aug 7, 2009 | 03:18 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: JDM 97 B16a SiR-II OBD 2 Into EM1 Question
everythind is plug and play, except the dizzy, can't recall, but that's only 3 bolts anyway
put a new timing belt on that engine!!!
Old Aug 7, 2009 | 05:03 PM
eM1<3's Avatar
Ahh. I've heard to sides to this.
The guy steve from Hmotors says I still need to swap out the vtec solenoid, Dizzy, Intake manifold because it doesnt have the vaccume lines the ECU looks for, and the oil pump for the CKF
And i've heard others say what you said, but along with the oil pump. And that's it. Does anyone know 100%?
Old Aug 22, 2009 | 10:31 AM
b16_swap's Avatar
im doing the same exact swap right now and i saved a rack of loot by bypassing the ckf sensor wiring do the dizzy. and everything else neeeds to be changed.. this is because your going from obd2b to obd2a and if you want to pass emissions.. you need to run your factory ecu
Jgreen94
Jul 19, 2013 07:47 AM
BWFL
11
Feb 8, 2013 09:36 PM
fatboy803
Feb 14, 2010 05:28 PM
neil23
Nov 13, 2009 01:50 PM
hbkxtbone
Jan 5, 2005 04:12 PM
