skunk2 suspention question?
i just bought a car with skunk2 struts and adjustable coilovers, i also just bought a set of skunk2 springs to replace the coilovers, when i was taking off the strut i saw that the bushing that gos in between the spring and top of the strut is missing on all 4 struts, what is that spacer called? how would i go apon ordering a set of those so that i can install the springs?
thanks
thanks
I'm going to assume you meant the isolator that goes between the spring and the shock's upper mount (assuming you have an EG like your user name suggests).
Junkyard, Dealership, or any place that sells suspension components should have them.
http://www.suspension.com/COILS_SPRING_ISOLATORS.html
eluam
Suspension & Brakes
Dec 24, 2007 05:22 PM
