Installing Skunk2 Intake Manifold on b16a2
Old Aug 7, 2009 | 12:37 PM
jkalex05's Avatar
Default Installing Skunk2 Intake Manifold on b16a2
I have a b16a2 swap in my 96 EX coupe and ive done some basic stuff like cold air intake installs and other bolt on stuff but this seems to be the hardest thing im going to install.
Does anyone know of a DIY for a b16a2 install of a Skunk2 Pro Intake Manifold.
Would be greatly appreciated.
I found one for a GSR motor is that basically the same as a b16 install?
Old Aug 7, 2009 | 01:05 PM
bakomack's Avatar
Default Re: Installing Skunk2 Intake Manifold on b16a2
its the same steps as putting any intake manifold on a b16.
its not hard im sure you can figure it out
Old Aug 7, 2009 | 01:18 PM
jkalex05's Avatar
Only problem is I havn't put on any intake manifold on ever...
Old Aug 7, 2009 | 01:21 PM
Linked's Avatar
you didnt do the swap on your b16 ex?
basically unhook the throttle body from it (4 bolts)
unhook EVERYTHING ferom the manifold, idk exactly whats on it
unbolt the manifold from the head (idk how many bolts)
replace the gasket for both the throttle body and intake manifold
find the torque specs for the bolts and torque down
replace everything you hooked up
its pretty easy to imagine what needs to be done
Old Aug 7, 2009 | 01:22 PM
jdm602's Avatar
its pretty easy...even for a first-timer. just dont let anything fall in the chamber. lol.
Ruben19
50
Apr 4, 2006 12:55 AM
1hotcivicSi
Mar 25, 2004 10:31 AM
