b series shift linkage question
I have a b16 and my shift linkage is bad I don't know wat kind to replace it with. I bought the car with the b16 so I have no idea how it works..thanx
B16 linkage is what I use in mine. Not sure if an integra linkage will work.
Why do you think it's bad? Just wondering because they're simple steel rods, and don't really go bad most of the time unless you bend the hell out of one. Most of the problems can be solved with new bushings.
94 and because they were welded together and the weld is cracked almost all the way. Plus it's hard to find wat gear I'm in. It kinda feels like a rubberband is holding it on
im gussing it's a 94 b16 and by ur screen name it's in a ef right? wells hasport makes shift linkage for those years and swap...if you don't want to buy it then take the old linkage and get it rewelded
Its me DUB
Mar 2, 2007 08:42 AM
