Suspension & Brakes Theory, alignment, spring rates....
compensator arm installation question
Old Aug 7, 2009 | 10:48 AM
AllmotorGSReg's Avatar
Default compensator arm installation question
i got a new compensator arm for my car because the bushings are gone bolts stuck in them i got my car aligned but they couldnt do the rear toe because of this. My question is where the compensator arm bolts to the trailing arm, i backed that bolt all the way out but it hits the frame and theres not enough room to take the bolt out. Do i have to drop the trailing arm to get this bolt out so it will clear the frame? The helms said to take out the compensator arm you just drop the two bolts on the arm and it drops out. thanks in advance.
Old Aug 7, 2009 | 12:11 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: compensator arm installation question
it is a tight fit. im assuming it is that inside bolt. if i remember right i had to use a swivle(sp??) and a longer extension but had to wiggle the bolt up there.
Old Aug 7, 2009 | 05:55 PM
stumpyf4's Avatar
Remove the inner bolt, then jack up the rear suspension so that it drops the nose of the trailing arm down... you should get enough clearance to remove the bolt.
Old Aug 8, 2009 | 04:51 PM
ya im talking about the outside bolt. so if i remove the inner then jack up the rear of teh car i should have clearence?
Old Apr 1, 2010 | 08:02 AM
triskpin's Avatar
I had to drop the trailing arm to get mine out on my DA. I think you could get it if you just take out the two bolts through the trailing arm bushing rod and drop the front end of the trailing arm a little bit..?
Charlie Moua
15
Sep 5, 2014 01:51 PM
bank2me
Aug 19, 2011 06:53 PM
JDMjackyboy
Jun 5, 2011 08:15 PM
mtrivera
Sep 30, 2008 05:57 PM
Sandals
Nov 22, 2005 04:02 PM
