Rear Caliper Replacement
Old Aug 7, 2009 | 09:56 AM
Aztex_Slingshot's Avatar
New User
Default Rear Caliper Replacement
I need to replace the rear calipers on my 1994 Civic with ABS. The brake hoses need to be disconnected from the brake lines since they screw directly into the caliper. Here is where the confusion sets in....when I looked at the manual it said that I need special tools to remove the lines/hoses on a car equipped with ABS, specifically a T-Handled Bleeder and an ALB Checker, there is no way I can get my hands on the ALB Checker. Can I disconnect the hoses and replace the calipers without having to worry about bleeding the ABS unit? And then just bleed the main braking system when the new calipers are installed? Also any tips or tricks on replacing the calipers and bleeding the brakes would be great.
Thanks
Old Aug 10, 2009 | 08:07 AM
New User
Default Re: Rear Caliper Replacement
Anyone? Help!
RACETEGGY
Jul 8, 2014 03:36 AM
NVturbo
May 27, 2008 12:53 PM
kit50si
13
Nov 18, 2006 06:06 AM
LilCivic04
Suspension & Brakes
Feb 17, 2005 09:05 AM
RickChew
Mar 4, 2003 07:29 AM
