JDM FRONT HELP!!!! AC lines
I am sure this has been said 1000 times but I couldnt find anything using the search. I am using the jdm oem hid headlights and the drivers side ballast is his the high side pressure fitting on the ac line coming off the canister.
how do I go ahead fixing this issue cause im sure im not the only one with this issue
thanks.
thanks.
You're not the only one. Just bend the AC line till the oem hid ballast fit thru. But when you bend the ac line, bend is slowly. I will take some pics 2moro if you want.
