What is this part? and what does it do? (fuel canister assembly)
Old Aug 6, 2009 | 08:51 PM
dropkneeyoungin's Avatar
Default What is this part? and what does it do? (fuel canister assembly)
http://www.acuraoemparts.com/delray/...All&vinsrch=no
part number 10 in the picture, its labeled as canister assembly.
i assume its for the fuel system, but i couldnt figure out exactly what it does.
can anyone enlighten me?
Old Aug 6, 2009 | 09:41 PM
WickedKP's Avatar
Default Re: What is this part? and what does it do? (fuel canister assembly)
A charcoal canister is used to trap the fuel vapors. The fuel vapors adhere to the charcoal, until the engine is started, and engine vacuum can be used to draw the vapors into the engine, so that they can be burned along with the fuel/air mixture.
Old Aug 6, 2009 | 10:39 PM
wow. thx, i honestly didnt know wut that was for. ive seen some cars without this canister, did those cars just "tuck" this part away or remove it completely? would removing this part affect my car in a bad manner?
Old Aug 7, 2009 | 07:11 AM
jamaicantourist's Avatar
DO NOT remove the fuel canister, it is there on purpose, lol
Old Aug 7, 2009 | 10:08 AM
Relic1's Avatar
if you're remaining OBD2, keep it or you'll be throwing CELs left and right.
the canister itself is part of the evaporative emissions system (not performance related in anyway) without it vapors from the fuel tank will be vented to the atmosphere.
If you're running OBD1, and have no need or desire to ever return to OBD2, it can be removed if you really want to.
Old Aug 7, 2009 | 10:19 AM
remove it... but DO NOT block it off if you do... lol, like driving around with a pressurised tank of fuel throwing matches at it
Old Aug 7, 2009 | 10:23 AM
Shalom's Avatar
And make sure the car never has to pass emissions ever again. People who turbo and convert to OBD-1 and then sweat it out when it comes time to renew their registration for their street car get laughed at.
Old Aug 7, 2009 | 11:40 AM
wow guys, thx a lot for the info.
i have the "purge" port blocked off on the canister (not my doing), wut does this mean?
Old Aug 7, 2009 | 01:01 PM
tipe R's Avatar
I believe that means that the fuel vapours in the canister wont be burned in the engine
Old Aug 7, 2009 | 03:44 PM
so they are just bleeding out in the bay or left in the tank? lol
when you open your gas tank cover does it go psssssssshhhhhhhhh for a long time? (over 5 seconds)
Old Aug 8, 2009 | 01:26 AM
nope. to my knowledge, everything works fine. my car is jrsc'd if that has anything to do with it.
Old Aug 8, 2009 | 02:13 PM
typerkiid2009's Avatar
yup they proably put it there for a reason
Old Oct 10, 2009 | 07:55 PM
GetEfdupEH's Avatar
sorry
Last edited by GetEfdupEH; Oct 10, 2009 at 07:56 PM. Reason: Idk how this happened
Type-Spaz
18
Feb 10, 2019 11:43 PM
lothian
Nov 8, 2018 02:04 AM
afnan
Apr 3, 2014 02:08 PM
beoy9
Aug 22, 2006 04:52 AM
EK22snatch
Aug 23, 2004 06:31 PM
