What do I need for a rear disc conversion?
Old Aug 24, 2002 | 08:00 PM
FourthGenHatch's Avatar
Default What do I need for a rear disc conversion?
On my 89 DX that is...
So far I believe the CRX Si's rear discs or a 90-93 Integra's rear discs should work right?
And for this I need the trailing arms and everything attached to them respectively. What else should I need?
If I wanted to get SS Brake Lines what car would I get them for?
Old Aug 24, 2002 | 08:05 PM
Loco Honkey's Avatar
Default Re: What do I need for a rear disc conversion? (FourthGenHatch)
This: https://honda-tech.com/zerosearch
And my take on rear discs are, if you don't have 'em, don't worry 'bout 'em.
Old Aug 25, 2002 | 04:31 AM
wronghand's Avatar
You will need the rear trailing arms, 90-91 CRX Si e-brake cables and proportioning valve. You may also want to pick up the rear sway bar as well. From what I understand the hatches have the necessary welded nuts to mount the sway bar. As far as the stainless brake lines 90-91 CRX Si lines should work fine.
wickedEFguy
Apr 22, 2010 12:19 PM
ROTEN EF8
May 8, 2007 06:35 PM
iheartmyh0nda
Apr 21, 2007 12:46 PM
NsX_CrX
May 28, 2004 08:21 AM
