IN 93 Civic SI, RHD, JDM goods, Buddy club. IN
SOLD SOLD SOLD SOLD SOLD SOLD SOLD...it is gone my friends
Please read everything before sending me a pm with any questions. I have given great detail in the description, but don't be afraid to ask questions. I have a List of vouch's on here if anyone wants some.
Car is located in Northwest Indiana.
1993 Honda Civic SI. Milano Red in color
NO Trades
Lowballers will be ignored
No free joyrides cause its RHD, unless you got cash on the spot
Price. $5,600.00
Clean Title, currently registered in Tennessee and has Current Tennessee plates until October 2009. I used to live in Tennessee, which is why it is registered, titled, and plated there. I have had no problems re-newing my plates in TN, where I lived in TN I had NO emissions.TN is more lenient than some states about their cars. Currently the car is here with me in Northwest Indiana.
_____Interior_____
The car has Original black interior and carpet. So that means black door panels, black rear plastics and black carpet are stock. This will come with the original LHD black dash set up, just for you to have. Will also come with a driver side teg seat to match the passenger side, if you want it. Also this car did NOT come with factory AC. That means HONDA didnt put AC in this car.
-Driver side Buddy Club Bucket seat- Wide Version
-Buddy Club Low Down Seat Rail
-Passenger Side Integra seat
-Rare JDM SIR-Vtec Integra rear seats
-Wink Rear view mirror
-GSR arm rest
- JDM RHD Honda Integra DC2 dash without passenger airbag (rare)
-JDM DC2 carbon Fiber climate control
-JDM DC2 Carbon Fiber gauge cluster
-JDM DC2 Carbon Fiber Driver side vent
-JDM RHD pedal assembly
-OEM honda Dual Din Block off plate
-Buddy Club shift ****
-OEM honda "black" Carpet
-Custom Tucked harness's ran underneath the dash..everything is protected by heat shrink and wire loomed.
-Tucked Fuse box underneath the dash behind the glove box.
_____Engine/Engine bay____
-Fresh Painted Milano Red (R81) engine bay
-Brake Booster Painted Nighthawk Black pearl, with gold flake in it. \
-GSR valve cover paint Nighthawk black pearl
-Spark plug cover painted Milano Red
-JDM RHD Clutch master cylinder
-Most bolts have been replaced with GOLD ones
-Tucked headlight and engine harness
-Custom Brake lines using Earls AN fittings
-Brand new OEM replacement Radiator
-Benen Radiator tie down
-JDM b16a with about 90,xxx miles on it
-JDM P30 ECU
-USDM GSR trans, grinds 3rd at high rpms/midrange. Pops out of 5th gear sometimes. Trans needs some help
-Exedy Clutch, does NOT slip or squeal. Grabs hard every time
-ITR "gold" shift linkage
-Energy Suspension Shifter bushings
-GSR duel bend shifter
-Recent axle replacements from NAPA
-OEM AC block off plate
-Odyssey Battery PC680-P
-Password JDM battery tie down
-Password JDM cam seal
-AEM cam gears
-USDM Type R cams
-GSR throttle body
-D-series throttle cable (a lot nicer looking than the RHD one thats 3 feet long)
-AEM cold air intake=
-Nextgear intake manifold gasket
-Comptech Header
-Custom test Pipe
-Apexi Dunk cat back ( rare and discontinued, was made for a DC2. but has been custom fit for EG)
-USDM GSR valve cover- Painted Nighthawk black pearl
-RHD windshield wipers
-RHD windshield wiper motor
_____Suspension/ Brake setup____
-Super Rare RHD POWER Steering Rack and Pinon
-Tokico Blues shocks
-Bomz Coilovers
-Custom bent brake lines using 3/16 lines from Autozone
-Custom brake lines using Earl's AN fittings. Each AN fitting was flared with the Rigid 37 degree flare tool.
-4040 prop valve tucked underneath the dash.
-Stock Rear disc brakes
-GSR front brake setup
- 7/8 Booster and Master cylinder, (upgraded from the stock 13/16)
-All my extra Earl's AN fittings and lines to do a tucked Fuel line and fuel filter I will include. They are not on the car.
____Wheels/Tires___
15 inch SSK rims. Polished
Falken tires, some camber wear in the rear..not to bad.
_____Exterior____
-JDM EG6 Headlights
-JDM Stanley Corner lights
-OEM Honda antenna block off plate
-JDM style Fog lights( Not hooked up)
-Rear Duck bill Spoiler painted Black
-New Windshield
-RHD wiper cowl cover
I purchased this car in Feb 2008 from a previous Honda-tech member. Since I have owned it, it has received a lot of new goods and a RHD conversion done the right way. The firewall was swapped out and was professionally installed by JIM REED Body shop in Nashville TN, by ASE and ICAR certified technicians. The paint that was used in the engine bay was Milano Red (R-81) using the brand Spies Hecker.( if you have never heard of it, look it up its Duponts High end German based paint. Super expensive.) Also using a Spies Hecker Clear coat 8180. It looks fantastic. The car starts up every time, NO CHECK ENGINE LIGHTS, motor does NOT smoke, does NOT make weird noises, IT runs like a champ, just the transmission is not in the greatest shape.I am starting to lose interest in this project because I have 5 other Honda's and it seems they all have become projects and I just need to cut down a little bit.
Cons
The previous owner had the hood fly up and hit the roof so its got a few dents up . The rear bumper has a crack in it, The driver side has stickers all over . (bad for some i guess) There is small spot of the "honda" rust starting to form on the rear quarter panels, nothing bad at all and can be fixed very easily. Hood has a few dings in it and is faded in color
In the pictures it shows a full size radiator that is just sitting in the engine bay. Since then I have installed a brand new half size radiator with a BENEN radiator holder.
NO Trades
Price. $5,600.00
_____Interior_____
-GSR arm rest
-JDM P30 ECU
-AEM cam gears
-USDM Type R cams
-GSR throttle body
-Comptech Header
-Custom test Pipe
-Bomz Coilovers
____Wheels/Tires___
_____Exterior____
-JDM EG6 Headlights
-New Windshield
Cons
good meeting yo to man .. hey my buddy has a pretty clean teal eg with bseries and a bunch of bolt ons .. he said keep ur wheels and ur seat and was wondering if ur interested
da6 sukkah
Jun 30, 2009 08:25 PM
theinfamouskonrad
Jul 24, 2005 01:15 PM
Insane Beast
Mar 23, 2005 11:07 AM
