Z10 Crossmember users....got a small problem.
Old Aug 24, 2002 | 07:56 PM
89civic1.8T's Avatar
Default Z10 Crossmember users....got a small problem.
I have noticed when I let my clutch out I hear a crunching/clicking sound from the front of my car. I though it was a bad ball joint or my brake pads where loose in the calipers but when I got under my car to check the sound seamed to be coming from the eyelets on the radius arms. Does anyone with these traction bars hear this sound?
Old Aug 25, 2002 | 08:39 AM
Tbone's Avatar
Default Re: Z10 Crossmember users....got a small problem. (89civic1.8T)
I haven't heard any crunching sounds from mine. Did you have your car aligned after you put them on? Are the actual bushings in the eyelets wearing out?
Old Aug 25, 2002 | 11:49 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i believe the Z10 radius rods are load adjustable. you might have slack in them, unperseptable by visual inspection, but as you launch (or just accelerate) the rods load up, tightening and making noises. try preloading them a little bit more.
stan
Old Aug 25, 2002 | 12:59 PM
NikoZai's Avatar
Default Re: Z10 Crossmember users....got a small problem. (90crxsi)
i have a custom made 1 armed bastard of a Z10 crossmember (made before its time, same structure just no front arm, same rods) and those rods make a shitload of noise on mine, embarrasingly so. Creeaking up to lights, big ole THUNK when i launch, sounds like the whole front ends coming loose. I'm gona go lube the ******* like hell and see if i can get some of the squeeking to go away. Otherwise, tighten everything to spec and see if it helps. My torsion/lower strut bar make noise if they arent tightened too, so if you loosened those for anything recently check that as well.
[Modified by NikoZai, 10:00 PM 8/25/2002]
Old Aug 25, 2002 | 01:29 PM
Default Re: Z10 Crossmember users....got a small problem. (NikoZai)
Ya mines does it when I roll up to lights with my foot on the break. My car was aligned properly so putting more load on them will take it out of alingment. I guess some lube my be needed. Well aleast I know it's not just me.
Old Aug 25, 2002 | 04:05 PM
oldskool_rex's Avatar
not sure on the construction, but if there are heim joints in there at all some noise is to be expected. The adjustable panhard rod on my rex has heim joint ends and it makes a TON of noise. Click-clack, rattle-rattle, annoy-annoy.......
Old Aug 26, 2002 | 08:41 AM
NikoZai's Avatar
right after i posted last i went outside and greased those eyelets, no more scratchy squeeking sounds! the only noise is the thunk at takeoff and its not audible outside the car. sweeet. much nicer.
xTyFighterx
Suspension & Brakes
12
Jun 8, 2015 10:13 AM
Kingkodo
Aug 20, 2014 11:40 AM
black_cap
Oct 9, 2004 03:18 AM
Jester88Si
Jan 15, 2004 10:28 AM
Chevy Buff
Oct 1, 2002 05:49 PM
