Just need ideas as what could it be!!! NO gear
Hello all, just looking for some ideas as what could cause this. I have no gear at all, car starts fine, sounds fine. Its just the car wont engage in any gear. Gonna start work on it this weekend, looking for ideas to where to start. Small>big issues
what kind of car?
does it go into gear with the car off?
could be a leaking master/slave cylinder, or bad throw out bearing, or a bad pressure plate. good luck.
Separate the shift linkage from the transmission. Check to see if it'll shift directly at the shift rod.
Did something change prior to the problem occurring?
