rear tires wear inside + front rte viberation @ 70
Wheel bearing is typically not that hard to fix if you are mechanically inclined. Search the forums and you will find write-up's / more information.
This vibration your feeling is it coming from the steering wheel or do you feel it more in the seat? Your wheels could possibly be out of balance.
Whats your current suspension setup? Have you had an alignment?
Are you sure it's a wheel bearing. I thought one of mine was going bad on my hatch and turned out it was one of the fairly new tires on the car. Rotate your tires and see it the sound moves position.
Better yet.. Jack the car up.. Put it on a jack stand and inspect. Try spinning it around and see if you can duplicate the ''roaring'' sound.
whagkangmakulet
Jul 14, 2004 05:06 PM
