How hard to install sidemarkers? EK civic
I have a 2000 Honda Civic EX 4dr. I was wondering how difficult it would be to install these sidemarkers:
http://passwordjdm.com/product2.aspx?Product_ID=1400
Would I have to cut holes in my fenders, do any custom wiring, etc? Thanks
pretty easy and always works...well, 90% of the time
cut a hole in the fenders, measure correctly and tap the wires into the parking lights.
my boy has his DA side markers tapped into his turn signal tho so they blink when you have your signal on too...if thats what you want.
good luck!
good luck!
yes you have to cut holes in your fenders which is no big deal. as long as you measure carefully.
the wiring is no big deal all you have to tap into you turn signel wiring.
Here's some info from the FAQ which you may have missed. If you're doing this, the "correct" way to do it is to wire the sidemarkers to the turn signals so they only flash when you have your blinkers on.
http://www.giuffre.com/personal/side...idemarkers.pdf
https://honda-tech.com/forums/honda-accord-1990-2002-2/5th-gen-jdm-sidemarker-install-write-up-2576520/
http://www.talkjdm.com/showthread.php?t=518
Carlos-Wh0ree
Aug 5, 2009 11:18 PM
Captain JDM
Jun 13, 2007 04:49 PM
sicksiguy
Apr 13, 2007 02:40 PM
locomex4life16
Sep 26, 2004 07:48 PM
