Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
*Urgent* clutch lost tension
Old Aug 6, 2009 | 11:12 AM
Reebok4146's Avatar
Default *Urgent* clutch lost tension
alright guys i need ur help desperetly....today i tried to do the squeaky clutch fix but i ran into a problem
when i tried to reassemble everything the clutch pedal only has tension halfway down
i noticed that my clutch fluid container is below minimum, maybe that might be the problem....can someone please help thanks
Old Aug 6, 2009 | 11:41 AM
It Wasn't Me's Avatar
Default Re: *Urgent* clutch lost tension
Wait... what? Reassemble? All I've ever had to do was spray a little white lithium grease and, voila!
What exactly did you take apart?
Old Aug 6, 2009 | 12:58 PM
Reebok4146's Avatar
i took out the slave cylinder and the rubber boot
turns out i did everything right i just had to bleed the clutch and add more fluid....
now im adding in my amsoil synchromesh
Old Aug 6, 2009 | 01:19 PM
Oh. Well, problem solved then!
jrap1243
11
Jan 9, 2008 09:18 PM
iLOVEmyEMone
Oct 28, 2005 05:31 PM
Flexer
Apr 16, 2004 07:43 AM
JDEM1
Jan 28, 2003 11:07 PM
pr0digy1
Apr 18, 2002 09:59 AM
