radio code
Old Aug 6, 2009 | 08:17 AM
ChiLS's Avatar
Default radio code
Can anyone get me a radio code because my car got broken into and i need to put my stock radio back in but lost the code to it?
Old Aug 6, 2009 | 08:34 AM
jhammond_82's Avatar
Reject Papi
Default Re: radio code
call or go to the stealership and they will give you the code by using your vin number.
Old Aug 6, 2009 | 09:38 AM
follie gatts's Avatar
i always call an acura dealership on the other side of the country. i've called cerrano acura in california, and another dealer in denver, colorado but the name escapes me.
if you search you will turn up threads about radio codes all over that recommend which dealerships will help you over the phone.
you could try sending a PM to RabbitNSI with your radio serial number. he has provided codes in the past, but has never helped me personally.
Old Aug 6, 2009 | 10:25 AM
wvridgerunner's Avatar
https://radio-navicode.honda.com/
Check on this link, it should be able to help you out.
Old Aug 6, 2009 | 10:42 AM
sure, if you are the original owner.
Originally Posted by honda.com
For security purposes, we verify ownership by comparing the phone number, zip code, and VIN you enter with those we have on file. Unless you have updated these values through Customer Services, the phone number and zip code will be those on file at the time the vehicle was purchased.
ALLxMOTOR EG's Avatar
Vietnamese!
Dealership.
Old Aug 6, 2009 | 04:47 PM
izzyaccord's Avatar
go to the dealership and show proof that you own that vehicle and they will give you the code
Old Aug 6, 2009 | 05:14 PM
Zappythebum's Avatar
i went to the dealership and got mine using the code i found on the inner panel of my glove box, gave it to the tech and they ran it thru the computer system and gave me back the code :] i believe the code is on the inner part (towards the center console) of the glove box but i could be mistaken, it had a bar code on it.
so yeah.. go to the dealership
Old Aug 7, 2009 | 12:53 PM
that's a sticker that came with the car. the dealerships could have stuck the sticker in the glove box, on the bottom of the removable ash tray, in the owner's manual booklet, or nowhere at all. it's hit or miss whether your radio serial number sticker has been stuck somewhere on the car. you can pull the radio and read the serial number off the unit itself, or look at the back of it from your passenger side floor to see if you can read it without pulling the radio at all.
Old Aug 7, 2009 | 01:11 PM
LOVEthatDC2's Avatar
theres also a number on the bottom of the radio you can read to them just call the dealership
Old Aug 7, 2009 | 04:47 PM
xantavar's Avatar
if you have the owner's manual, sometimes the sticker is placed in there or the number is written down.
Old Aug 7, 2009 | 09:28 PM
samsyabi's Avatar
You will have to get it by the manufacturer?
Rowdy Rod
Aug 19, 2011 09:29 AM
DipStick
Acura TL, RL & ZDX
Apr 7, 2011 11:51 AM
neoway
Acura TL, RL & ZDX
Sep 21, 2010 10:30 PM
here4advise
Acura TL, RL & ZDX
20
Oct 10, 2009 03:11 PM
yaoau
Acura TL, RL & ZDX
Dec 1, 2008 02:23 AM
