Rocket LS cams, who has them?
Old Aug 24, 2002 | 06:41 PM
No-Gi's Avatar
Default Rocket LS cams, who has them?
I just want to know how many of you guys are running Rockets' camshafts?
What are your setups and if you have any dyno results?? I am considering the Medium Spec for my Stock bottom end JDM b20b.
Old Aug 24, 2002 | 07:10 PM
lazy bum shaughn's Avatar
Default Re: Rocket LS cams, who has them? (B16aEK)
Rockets' camshafts?
Old Aug 24, 2002 | 07:51 PM
neo1z's Avatar
Default Re: Rocket LS cams, who has them? (Mixxed Bboy)
geez ive never even heard of them...
Old Aug 24, 2002 | 09:46 PM
JalopySiR's Avatar
You may want to talk to Rocket. I assume you got this from the archived "b20 cams" post. I am currently running the small grind(regind) It is very nice. Doesn't fall off up top, keeps pulling. I should have dyno results by the 7th. BTW, talk to Rocket, he is a great guy and knows his shizzle. He won't steer you wrong. Also, I do not reccomend cams for this setup until you have a good intake, Skunk2 IM, header, high flow cat, and exhaust. While I feel the gain from the cams, they are being severly restricted by the stock 90-91 Teg IM and exh. manifolds I am currently using. This is also on the small grind, the medium, which is quite large, will be worse. I don't know of anyone else using these cams yet, they are fairly new, but HondaSaver is up and coming!
Old Sep 6, 2002 | 10:06 PM
Rocket's Avatar
Default Re: Rocket LS cams, who has them? (JalopySiR)
Thanks, Alex.
The small grind works great with the stock ecu and has better idle than the other brands available.
To run the bigger grinds I suggest getting valve springs.
Old Sep 6, 2002 | 10:12 PM
The Rob's Avatar
Default Re: Rocket LS cams, who has them? (Rocket)
I'd run them if I could.
Old Sep 6, 2002 | 10:14 PM
Rocket's Avatar
Default Re: Rocket LS cams, who has them? (Zero Effect)
Save your money for a GSR head. I may have some available soon.
bewarecrx
Jun 14, 2010 06:26 PM
px_R
Sep 10, 2006 10:55 AM
BlackRocket
18
Nov 9, 2004 05:19 PM
8krdline
Sep 22, 2004 05:53 PM
itbtype-r
Jun 1, 2004 04:16 PM
