Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic ex Driver side engine mount
Old Aug 6, 2009 | 05:48 AM
ep2integra's Avatar
Default Civic ex Driver side engine mount
Im in desperate need of a uprated mount/rubber because its the second time ive broke the rubber and need this sorted.
The engine is a d17, left hand drive on a 04 plate.
Thanks.
Old Aug 6, 2009 | 06:01 AM
daddy's Avatar
Default Re: Civic ex Driver side engine mount
check your other mounts. sounds like something else is bad to cause that one to wear out so prematurely.
Old Aug 6, 2009 | 06:04 AM
ep2integra's Avatar
well basically the others have all be uprated. The car is turbo'd and running about 230bhp. So its because its got the most movment.
Old Aug 6, 2009 | 08:22 AM
It Wasn't Me's Avatar
I'm a bit confused here. You were able to upgrade the others without anyone's help, but left this particular mount untouched.. for some reason. That part is clear. What doesn't make sense is why you're in need of assistance with this one, when assistance wasn't required to do the others.
Anyhow.. this was among the Search results and is less than two weeks old. https://honda-tech.com/forums/honda-civic-2001-2005-78/motor-mount-troubles-what-do-what-do-2613606/
HC4
Honda CR-V & Element
Jul 1, 2019 11:34 AM
fluke702
May 14, 2009 05:23 PM
littlered
Jan 23, 2007 11:10 AM
Loveless
Oct 14, 2003 09:52 AM
balistic CRX
Dec 27, 2001 04:37 AM
