EG Hatch Sputtering/Choking
Old Aug 5, 2009 | 11:27 PM
.::B00stin2High::.'s Avatar
Default EG Hatch Sputtering/Choking
I have a B18C swapped EG and its been acting weird.
Sometimes when I warm it up the idle stay might go really low almost dieing but it doesn't. It died a couple of times today on the freeway. Then it sputters, hesitates, and chokes a little. It gets better if I just gas it.
When I'm at a stoplight after this happens the idle goes down below 500 RPM then goes back up. Not sure what it could be. Spark plugs were changed not long ago.
I'm thinking either the CAI filter or Air flow sensor? Any help appreciated.
Old Aug 6, 2009 | 12:17 PM
Default Re: EG Hatch Sputtering/Choking
bump....anyone??
Old Aug 6, 2009 | 06:11 PM
I'm thinking its the spark plug wires or the plugs themselves....? It's missing a cylinder from what I can tell.
Old Aug 6, 2009 | 06:58 PM
honda_boy23's Avatar
when it died on the freeway did you throw any codes? becasue i went threw kind of the same thing with my ek
Old Aug 7, 2009 | 10:26 AM
HalfAnP's Avatar
From: I put on my robe and wizard hat, NY...err Bay Area--->Texas
I don't think a bad MAF would do this. I say check the plugs and wires. Esp. the wires since you said you changed the plugs.
Old Aug 7, 2009 | 11:57 AM
Former User's Avatar
Check the plugs, wires, cap, and rotor. Also try cleaning the IACV and FITV on the throttle body.
Old Aug 7, 2009 | 06:51 PM
No, didn't throw any codes.
Yea, my friend said it's the plugs or the wires. Most likely the wires. Is it recommended to change wires while you change plugs?
Will do. Just use brake cleaner or what?
Old Aug 7, 2009 | 10:28 PM
That or carburetor cleaner.
Lewsears
Mar 20, 2010 09:25 AM
manny81
Mar 13, 2009 04:06 PM
BigMikeyStyle247
Apr 23, 2007 02:56 PM
IamVtec
14
Apr 12, 2003 08:10 AM
nijia555
Jun 4, 2002 04:37 AM
