Whats wrong with my windsheild wiper?
Old Aug 5, 2009 | 10:50 PM
FRKWOO's Avatar
Default Whats wrong with my windsheild wiper?
recently the first turn wipers failed...? the second click works fine also the third turn and when you spray the wiper fluid it will go on automatically & still works perfectly the only thing that doesn't work is the first click the slow every 5 secs wipe doesn't work. anyone whats wrong thanks!!!
Old Aug 5, 2009 | 10:57 PM
Ruben19's Avatar
Default Re: Whats wrong with my windsheild wiper?
time for a new switch .
Old Aug 6, 2009 | 02:13 AM
EKSiR99's Avatar
the switch is broken... you need to get a new or a surplus would do
Old Aug 6, 2009 | 10:00 AM
FRKWOO's Avatar
what do u guys mean by the switch?
Old Aug 6, 2009 | 10:02 AM
kaiba's Avatar
Either the wiper switch is bad or the thing behind the fuse box is.
Old Aug 6, 2009 | 10:14 AM
hOnda_hiEn's Avatar
leave it be. and just use it manually..
hOnda_hiEn's Avatar
oh wait.. youre in seattle.. LOL.. might need to fix that.. rain 24/7
Old Aug 6, 2009 | 11:11 AM
Relic1's Avatar
first click as in low speed or int?
int - I'd check the module plugged into the back of the fuse box.
low - if the wiper returns to the bottom of the windshield when you turn it off mid wipe, then it's likely a switch problem.
This is for an EG, but I'd done the same on EKs. http://www.b18c5eg.com/how2/wiperswitch/ - (this could resolve the int issue as well)
Old Aug 6, 2009 | 11:37 AM
chrisfromsrq's Avatar
i have the same problem. the int doesnt work. and when i turn my wipers off they stop where ever they are at. they dont go back down i have to mess with it to get them down. i got a switch from the junkyard and still the same thing. any other solutions?
Old Aug 6, 2009 | 11:44 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Wow, such a mix of helpful and unhelpful advice here. I'd check out the switch as Relic1 suggests. Check out this DIY link by danomatic: DIY Combination Switch Fix (Headlight Switch) AND Wiper Combo Switch
I doubt it's the ICU module behind the fuse box ... also doubt it's the wiper motor itself, but these are all potential other locations where the problem could reside. Try the switch fix first ... swap in a known good if you can before you fix it to save yourself some time.
GL.
wseg
Mar 3, 2010 03:35 PM
go2sleep
Sep 2, 2007 10:08 AM
supraken
Jul 23, 2007 07:43 AM
Ls_V_TurboSi
Oct 7, 2006 06:25 PM
capedave
Nov 15, 2004 03:23 AM
