NSX / Legend(?) AirBox on ITR?
Although I can't recall the thread where I read it at, there are teams that use the NSX airbox on the ITR. Has anyone done this yet... using the NSX (or Legend?) airbox+filter on their ITR?
I assume that they the NSX/Legend are the same, but it is probably "cheaper" to get the Legend version.
If so, what model year Legend is it off of (or can it be from any year), and does it bolt right in or modifications are needed? Is it just the airbox, or is it an airbox/resonator setup kind of like the OEM ITR... it's just "bigger"?
Realtime is the team that is most famous for doing this.
You will need to remove your ABS to install a NSX airbox.
That alone makes it not worth it.
ITR ABS is VERY GOOD.
would you?
