obd0 to obd1 jumper harness
Old Aug 5, 2009 | 07:25 PM
ef602's Avatar
Default obd0 to obd1 jumper harness
do jumper harnesses include wires to wire up your distributor? I just dropped in a z6 into my dx. I was told that the wires that come with the jumper have wires for your injectors, vtec, o2 but i was not sure about the dizzy. Can someone help me i looked online but all the info i found is a bit confusing. I just want to get my car running because it is my dd and i am low on funds to pay someone to do it.
Old Aug 5, 2009 | 07:27 PM
D16SiHatch's Avatar
Default Re: obd0 to obd1 jumper harness
the ecu jumper is seperate from the smaller jumper harness which allows you to plug an obd1 dizzy into your obd0 harness.
Old Aug 5, 2009 | 07:30 PM
ef602's Avatar
can you give me more info or even get me to the right direction with some step by step instructions? Btw my car is dpfi currently!
Old Aug 5, 2009 | 08:46 PM
D16SiHatch's Avatar
well first you'll need to convert it from dpfi to mpfi
http://hondaswap.com/swap-articles/d...writeup-49557/
then pick up this ecu jumper and distributor adapter combo from rywire
http://rywire.com/store/8891-crxcivi...bc855073336071
included with this is the subharness that you will run into the engine bay and plug directly into your vtec solenoid and vtec pressure switch, as well as your 4 wire o2 sensor.
Pancho2193
Mar 4, 2013 05:33 AM
efjones9
23
Jan 17, 2009 04:20 PM
BseriesEG
Sep 11, 2007 07:08 PM
jtroy917
Jun 3, 2007 02:54 PM
Novtecdohc
Aug 18, 2005 06:32 PM
