zc questions/websites?
Old Aug 24, 2002 | 06:11 PM
wannab20hatch's Avatar
Default zc questions/websites?
Planning on buying a 91civic hatchback and it needs a tranny so im thniking about just putting a zc in it for now and using it for a daily drivier.Does anyone know any websites that talk about zc and what parts can be used(such as water pumps,timing belts,etc.). Or can anyone tell me the redline of the zc motor and specs on it? thanks for all the help.
[Modified by wannab20hatch, 3:12 AM 8/25/2002]
Old Aug 24, 2002 | 11:28 PM
bryant's Avatar
Default Re: zc questions/websites? (wannab20hatch)
just search https://honda-tech.com/zerosearch , http://www.google.com
Old Aug 26, 2002 | 08:25 PM
TREVER's Avatar
hybrid forget the address
[Modified by TREVER, 9:25 PM 8/26/2002]
Old Aug 26, 2002 | 09:26 PM
Katman's Avatar
....zc and what parts can be used(such as water pumps,timing belts,etc.). Or can anyone tell me the redline of the zc motor and specs on it? thanks for all the help.
Ok, since your buying a 91 EF hatchback, you'll need to buy a JDM 89-91 ZC engine this particular year/series is designed for an EF chassis. This motor is rated at 130hp; compression ratio is 9.5; the jdm PM7 ecu redlines at 7500rpm, and if happen to not get the JDM/PM7 ecu with your ZC engine, don't fret, you can use a US 88-89 Integra ECU (PG7 I believe). It redlines at the same rpm also (7500).
If memory serves me right, the timing belt from a US 88 prelude is the belt you'd wanna use for a replacement. Same goes for the headgasket also (88 lude).
svacca1
Sep 15, 2007 06:52 PM
DesiDez
Jun 10, 2003 12:41 PM
DarkZachiel
10
Sep 2, 2002 10:09 AM
AMChev
25
Apr 2, 2002 08:27 AM
allmotorEG-SI
Oct 1, 2001 01:19 PM
