knocking sound along the front tire of 96 honda accord
Hi, I need help, I'm hearing a knocking sound whenever my car goes down down on a low curb side of the road or on a small pot hole (around 2" deep), any idea on what it is, will it be the ball joint?
Lift the car in the air with a shop lift or jackstands and check all ball joints for freeplay. If there is perceptible play in any of the four front ball joints (one upper and one lower on each side), replace the joint immediately. Also check the tie rods for play in both the inner and outer joints, and inspect the front upper control arm inner pivot bushings, the sway bar endlinks, sway bar bushings, and upper shock mount bushings. The lower control arm bushings aren't often bad, but check them as well. Make sure the coil springs have no broken coils.
Hey, thank you for your immediate reply, I will check those this weekend, since I'm gonna still use the car for a week or two, will it be safe to use the car let say with the bad ball joint?
similar problem here, I got a knocking sound when ever i brake.
__________________________________________________ ____
$29 auto insurance for student ages 16-24
@ http://www.localdiscountautoinsurance.com/
I guarantee this will help you save a lot of money.
nalley0710
Apr 24, 2013 01:32 PM
