throwing a code 43
I have a 1994 civic Ex with i/e, i went on vacation for a week and left it sit. my car was running great when i left then when i came back it felt like it was missing and stumbling and just running like crap. I replaced injectors, Fuel Filter, REgulator, 02 sensor and the pressure is 40 psi, but it still runs this way. I have researched this problem and found nothing to help so any help would be great.
if you disconnect each fuel injector one at a time while the engine is idling, do some disconnected injectors make the engine run worse while others do not? Have you inspected the spark plugs to see if any differ in appearance? How do the cap and rotor look?
I read this in your original post. If the injectors worked all by themselves, then this would also be the final answer. However, the fuel injectors must receive power from the main relay and a signal from the ECU to know when to fire. These signals are relayed through wires. Hence, the unplugging test has some potential to yield important information.
Other items worth testing: Fuel pressure without FPR vacuum hose attached and the ignition coil.
Good luck
Good luck
If disconnecting one of the injector clips had failed to make the engine run worse, then there is a problem in the circuit for that injector.
so since it ran worse then everything is fine with the circuit,, oh and the ignition coil is brand new so i know that is not it.. but what would happen i i just unplugged that vacuum hose would that determine anyhing
It might be interesting to see whether unplugging the FPR hose has an effect. Make sure you block the end of the disconnected hose with your finger when you do the test. Otherwise the engine idle speed will increase. When you do this, also check whether the hose is pulling vacuum.
Do you have or can you borrow a timing gun to check the ignition timing?
no but i dont think its the timeing cause it was running fine a two weeks ago i was gone for a week then ran like crap when i got home it was sitting but was started twice
