what bracket this is? rear sway bar issue
k so i been meaning to put my rear sway bar and everytime i try there is somethign else i need. so far i got the rear LCA the sway bar (GSR), stock GSR endlinks. Now i found out that i need a brackcket that connects the D bracket with the subframe. k so i went to honda and now they said that the 92-95 civic hb si didnt come with rear sway bar. so i was like WTF, duh i think only in japan they came with rear sway bar.
the part im lookign for is number 30 in the lowered diagram. However this is for 99-00 si. i couldnt find the diagram for the 92-95.
Does anyone know where i can get this. I live in canada btw so im not sure if the states civic is different. whats the part number for this or what 92-95 civic had rear sway bar.
Thanks
Thanks
go to your acura dealer...the brackets should be around 25 bucks just tell them you need a sway bar bracket for 2001 integra gsr. i just bought some online from delray honda, its cheaper there I'm doing the same thing to my del sol and hatch
so your saying that the integra bracket should fit 92-95 civic as well. so the civic subframe is the same as the integra subframe then?
yeah....its either that or you can buy ones from 00 4dr civic ex with side air bags or 95 civic ex with srs air bags. ( you have to be specific because if you go to honda and tell them ex civic, they will pull up a diagram without sway bar. you have to tell them the one with side air bags. let me know how it goes.
I actually tried to look for some proof as to what you said about the integra and SIR subframe being the same as to the 92-95 civic but i couldnt find any. They look the same but mmmmm i needed some more proof. I tried looking for ASR subframes and they list different part number for 92-95 and 96-00. Could you help me out?
Spoon-EK9
Suspension & Brakes
Jan 29, 2006 08:14 PM
Jchild420
May 20, 2004 08:55 PM
