A couple lug nut questions.
I'm picking up a set of konig heliums, so I know i'll need conical lug nuts. From there on is where I'm confused.
1. open vs. closed? are open lugs only for extended studs?
2. what length do i want? would these work?
thanks.
thanks.
thanks.
thanks.
2) Yes those will work, as long as Heliums use a standard 60* taper seat.
Closed lugs protect the studs from corroding, look better and weigh a little more. The perfect (shortest you can use) nut length would depend on the wheels but those are plenty long enough.
TurboLude97
Feb 20, 2003 12:37 PM
