b18b1 cam seal issues
Any suggestions as to why my cam seals repeatedly keep leaking ive replaced them 3x's shown them some love with rtv my guess is that the valve cover is warped because im am always finding oil in with the spark plugs any other suggestions would be great motor is torn apart again so anything said will be tried. Thanks.
A leaking cam seal has nothing to do with oil on spark plugs. You need to replace the spark plug tube seals.
You're gonna replace the entire top end because your cam seal is leaking? How bad IS it leaking? Even it the valve cover was somehow warped, it would have to be noticeably bad for the gaskets not to make up for it. Are you sure you're torquing everything down correctly, using the right gasket/seals, putting the correct type of RTV in the correct locations?
jayWknight
Oct 16, 2012 04:37 PM
budget
Apr 11, 2006 05:56 PM
