????'s on rebuild
Old Aug 4, 2009 | 09:32 PM
bmwe362006's Avatar
Icon6 ????'s on rebuild
My motor has been smoking pretty bad lately and now it is time for a rebuild. It is a GSR w/ b16 head. I am planning on purchasing ctr pistons for it, and i was just curious on what kind of power gains i will be looking at. I have searched and found no definite answer.
Old Aug 5, 2009 | 07:58 AM
spidy3's Avatar
Default Re: ????'s on rebuild
your going to up the compression if you get ctr pistons I believe. I know the ITR pistons will. The gains will be minimal for numbers but the "butt dyno" might feel a little more pull in lower rpms
Old Aug 5, 2009 | 08:30 AM
PACT man's Avatar
ud be wasting ur time, too much compression, not enough supporting mods, wont feel any faster, may be slower even, plus the added risk of most likely having detontation,
if u want higher cp i wouldnt go past jdm p73 itr pistons, will give u a nice bump without too much
ur setup now is running around 9.8:1cp, assuming ur using the USDM block/pistons(hope u realize the b16 head lowers ur cp)
ur looking at 12.7:1cp on the ctr's(PCT)
the jdm p73 itr's will give u around 11.3:1
a stock USDM gsr has 10:1
ur motor wont like the high dome of the PCT piston either
lsvtec_hatchback
Aug 25, 2006 02:18 PM
B-B-K
Sep 7, 2005 01:42 PM
kenepo_vtec
Aug 26, 2004 12:34 AM
boobz
Jul 25, 2004 08:48 PM
philafelman
28
Sep 28, 2003 11:37 AM
