How to change oil pan??
Old Aug 4, 2009 | 09:16 PM
chieftaco's Avatar
Default How to change oil pan??
Is it as simple as it seems....unbolt, new pan and gasket, and then bolt back up or do I have to unbolt and re-bolt in a specific order? It's on a 94 lx model. Thanks...
Old Aug 4, 2009 | 11:05 PM
joker4096's Avatar
Default Re: How to change oil pan??
there is a specific order to re bolt it. grab a repair manual
Old Aug 5, 2009 | 03:34 AM
hondamark35's Avatar
Keep in mind that the exhaust (manifold to cat) must be removed first. sometimes the transmission dust cover needs to come off for easy access to a few of the pan bolts.
joker4096 is right, you'll want to have that manual nearby for reference when you're in the middle of replacing the pan...
Old Aug 5, 2009 | 05:11 AM
TouringAccord's Avatar
H-T Order of Merit
if you search, you should be able to find the steps and order the bolts need to be torque in. I know I posted that info before.
Forrie
Feb 12, 2012 04:14 AM
vectorsc
Mar 31, 2008 06:26 PM
9 CRX si 1
May 20, 2006 11:50 AM
baphomet
Dec 19, 2005 01:41 PM
dynomax27
Oct 15, 2002 04:22 PM
