Suspension & Brakes Theory, alignment, spring rates....
jdm 23mm itr rear sway bar bushing parts numbers the same as us 22mm
Old Aug 4, 2009 | 07:19 PM
2001B18C1GS-R's Avatar
Default jdm 23mm itr rear sway bar bushing parts numbers the same as us 22mm
jdm 23mm itr rear sway bar bushing are they the same part number as usdm 22 rear sway bar
i need the d bracket with bushing and the endlinks with bushing and lil metal sleeve i was told they are the same and someone else say no so help me out people i need new bushing
Old Aug 4, 2009 | 07:42 PM
Egezzy's Avatar
Spongebrad Squarepants
Default Re: jdm 23mm itr rear sway bar bushing parts numbers the same as us 22mm
i used usdm itr bushings in my 23mm.
place to get prothane bushings.
http://www.heeltoeauto.com/Prothane-...-pr-42011.html
a writeup for you.
http://hybrid.honda-perf.org/tech/ITRon5G.html
Old Aug 4, 2009 | 07:47 PM
a writeup for you.
yea i want all oem stuff its the best i dont like anything other then OEM
also did you use ur stock oem 22mm d bracket, d bushing endlinks and endlinks bushing
Old Aug 4, 2009 | 08:39 PM
Egezzy's Avatar
no sir. just the endlink hole bushings. prothane for the d bracket setup.
Old Aug 5, 2009 | 05:36 AM
someone one here must know if there the same part numbers
Old Aug 5, 2009 | 07:10 AM
Egezzy's Avatar
i would guess that the numbers are different due to the bar ODs being different.
B serious
Feb 16, 2010 01:42 PM
Another Drew
May 12, 2009 07:08 AM
bcpEG
May 8, 2009 07:28 PM
volcomstoned
Suspension & Brakes
Nov 30, 2008 06:02 AM
