Suspension & Brakes Theory, alignment, spring rates....
ST rear swaybar install help on my '98 DX...
Old Aug 4, 2009 | 04:26 PM
JDMADD1CT's Avatar
Default ST rear swaybar install help on my '98 DX...
I need help installing my Suspension Techniques rear sway bar I just bought off another member. I have a '98 DX w Function7 LCA's. I have DC2 rear suspension, not the fork suspension like stock Civics, but I dont think thats an issue(?). When I line up the bar, I know where the D-brackets go, but where do the ends of the bar get attached to? I tried searching, but only found info on the fronts, regarding you need a part from the Si. Am I missing something, or do I need something else? Any help is appreciated
Old Aug 4, 2009 | 04:30 PM
randomtask77's Avatar
Default Re: ST rear swaybar install help on my '98 DX...
I'm guessing you need endlinks? This is where the ends of the sway bar get bolted to the rear LCA's.
Old Aug 4, 2009 | 08:44 PM
Egezzy's Avatar
Spongebrad Squarepants
#31/32 are the endlinks
Old Aug 4, 2009 | 09:43 PM
racebum's Avatar
both of the above are likely wrong. the ST bars use bolts with poly pushings and actually attach at the shock bolt. ST builds them this way as a kit so people with no sway bar mounts don't have to buy new LCA's
http://www.autoanything.com/suspensi...A3366A0A0.aspx
see the bolts and bushings pictured? you basically use a 90deg piece of plate metal off the back of a shock lower bolt, then use the bolt and poly bushings to attach. if you didn't get all these parts i would contact ST suspension and buy the correct mounting kit. this is NOT a bar you want to buy bare by itself. they come as a package. i actually have a 19mm ST bar on the back of my integra. if you need help let me know and i can take a pic.
Old Aug 5, 2009 | 12:46 PM
racebum's Avatar
photos for the thread
Old Aug 5, 2009 | 01:18 PM
Egezzy's Avatar
for the pics. good to know the st setup is diff.
Old Aug 6, 2009 | 07:46 AM
Were the bolts also included with the sway bar? I mean the longer shock bolts that hold the "L" bracket that goes through the LCA?
Old Aug 6, 2009 | 12:09 PM
racebum's Avatar
stock bolts are used. you won't need anything longer, that plate metal is 3/16ths tops, might be 1/8th.
Old Aug 6, 2009 | 03:20 PM
JDMADD1CT's Avatar
yeah, BIG to idrivesideways for the info & those pics! BIG HELP! i got those long bolts/bushings w the bar, just not the L-shaped brackets. prob gonna make custom ones
Joon Joon
Suspension & Brakes
Jun 29, 2010 10:21 AM
Hairy Hudson
May 14, 2008 07:24 PM
crx4luke
Nov 9, 2006 05:24 PM
GloomyX
Suspension & Brakes
Oct 1, 2006 09:10 PM
Nothing.Special
Suspension & Brakes
May 17, 2005 05:46 PM
