DSS 5.9 Knuckle question
Putting a set of 5.9s onto a 99 DX Hatch. DSS specifically says to use 96-00 ABS knuckles. The salvage place I am getting them from says that the EX non-abs and EX abs are the same. Is this true? Will the non-abs EX work for me?
Thanks, Brian
Thanks, Brian
I just check the part numbers on Majestics site for a 99 DX and 99 EXw/ABS for some reason the Right axles are different. Lefts are the same part number.
here,
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=1999&catcgry3=3DR+DX&catcgry4=KA5MT&catcgry5=DRI VESHAFT+(2)
http://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=1999&catcgry3=2DR+EX+ABS&catcgry4=KA4AT&catcgry5 =DRIVESHAFT+(2)
Hope that helps.
here,
Hope that helps.
http://www.hondaphttp://www.hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=CIVIC&catcgry 2=1999&catcgry3=2DR+EX+ABS&catcgry4=KA4AT&catcgry5 =DRIVESHAFT+(2)artscheap.com/southbay/jsp/prddisplay.jsp?hidSwitch=Switch&hidIrno=|004|005&c atcgry1=CIVIC&catcgry2=1999&catcgry3=2DR+EX+ABS&ca tcgry4=KA4AT&catcgry5=DRIVESHAFT+(2)&vinsrch=no&Li stAll=&prdrefno=&act=&count=0&quantity=0&qty0=1
There's another site that list the OEM p/n's If you ever have the need for it. Looks like Majestic's site has a error in the DX right axle p/n
here,
Hope that helps.
here,
Hope that helps.
Looks like the southbay site has the correct info. Most of them are the same part, and the same price.
But like miller said as long as you have the correct bearing size it will work.
99CivicExCoupe
Jul 28, 2004 01:04 AM
