RPMs bouncing in First Gear
Old Aug 4, 2009 | 01:56 PM
Radim's Avatar
Default RPMs bouncing in First Gear
So i've been having this problem when the car is in first, the rpms bounce or bog i guess a lot. Starts off fine to 2,200, then it hops up to 2.700 and then bogs down to 2,500 then jumps back up to 3,000 and so on.
It only happens in first, and happens pretty fast.
Anyone have any insight on what it could be?
Thanks in Advance!
Old Aug 4, 2009 | 05:15 PM
crxb16a90's Avatar
Default Re: RPMs bouncing in First Gear
hmm, check your dizzy, have u check your injector plug?, all ground?
Old Aug 4, 2009 | 05:35 PM
grog's Avatar
bad/ dirty FITV and IACV have done this to me. it would buck every time i would let off the gas. but it wouldn't rev that much i dont think. do you have a bouncing idle or idle problems?
Old Aug 4, 2009 | 06:32 PM
Radim's Avatar
Nah, idle is fine.
When i rev it in nuetral it's good, idle is good no bouncing at all @1,200RPMs warmed.
It only happens in first gear, when i step on the gas while it's going up in rpms it will bog several times but when i put it into 2nd-3rd-4th-5th it is perfect.
All grounds seem to be good, injectors are all working good, distributor is rebuilt.
The thing that weirds me out is that it ONLY happens in first gear.
Old Aug 4, 2009 | 06:34 PM
BiG ChOr!Zo's Avatar
change fuel filter,run fuel injector cleaner and check your spark plug wires...!!!
Old Aug 4, 2009 | 06:36 PM
Radim's Avatar
Spark plugs wires were replaced, ask Wayne why.
I put seafoam in the gas tank to clean out the injectors, fuel filter i haven't changed i'll buy a new one tomorrow
Old Aug 4, 2009 | 06:43 PM
wayne aint online right now...!!!
Old Aug 4, 2009 | 07:04 PM
Radim's Avatar
Damn, that girl is ugly.
She your girl?
Old Aug 4, 2009 | 10:43 PM
dcvt16's Avatar
check for vacuum leaks.
Old Aug 4, 2009 | 10:52 PM
Radim's Avatar
Cool cool, i'll give that a check tomorrow.... Is it carb cleaner that you spray on the lines?
Old Aug 5, 2009 | 02:37 AM
Matt6387's Avatar
or soapy water
MLevinson
Jun 22, 2008 06:35 PM
napalm588
Nov 5, 2007 06:46 AM
lunarone
Sep 20, 2007 05:28 PM
94acurals
Aug 21, 2007 02:47 PM
99em1_sir
Jul 30, 2007 07:28 PM
