b20 overheat
Old Aug 4, 2009 | 10:58 AM
felipe69's Avatar
Default b20 overheat
Hey I have an ef hatch wit b20 vtec! I'm wondering y its overheating?? The hose that runs to the thermostat and the radiator is way cooler than the top hose!! It does not get as hot!! I tried taking off the thermo to see if that's the prob but it still did the same! Anyone out there have any suggestions or solution!
Old Aug 4, 2009 | 11:59 AM
ek-g6's Avatar
Default Re: b20 overheat
Do you see any leaking of coolant? The bottom hose tend to run colder, but if its really cold, then radiator could be plugged up. When does it overheat? I would also check the thermostat may not be opening up.
93grayeg
Jan 31, 2011 10:46 AM
supra-n-civic
Jan 24, 2010 08:39 AM
1_slo_ef
Mar 20, 2007 12:41 PM
daver
Aug 6, 2002 04:34 PM
