Are JDM ITR LCA same as USDM ITR LCAs?
Old Aug 4, 2009 | 09:52 AM
s13hero's Avatar
Default Are JDM ITR LCA same as USDM ITR LCAs?
Old Aug 4, 2009 | 04:00 PM
omiehomie's Avatar
Default Re: Are JDM ITR LCA same as USDM ITR LCAs?
Originally Posted by s13hero
Are JDM ITR REAR LCA same as USDM ITR REAR LCAs?
yes...
Old Aug 4, 2009 | 04:31 PM
s13hero's Avatar
Okay, thanks, do you know if JDM non type R are different than USDM non type R?
Old Aug 4, 2009 | 07:15 PM
Little_Nolan's Avatar
Depends on the trim level of the car you are refering to.
Old Aug 5, 2009 | 03:58 PM
s13hero's Avatar
Okay, so this might be kind of confusing, but I was under the impression that USDM ITR LCAs were the same as the USDM Integra, and I asked in the civic forum if integra suspension will bolt onto eg hatch, and I got a yes. Therefore, only JDM type R suspension would differ from the USDM regardless of being a type R or not. I'm still not sure about JDM non-type R, but this thread would say otherwise.
Old Aug 5, 2009 | 04:30 PM
USDMCIVICHATCH's Avatar
Any suspension USDM or JDM from a 94-01 Integra Type R or non Type R will fit any 92-95 civic. I hope that answers your question.
Old Aug 5, 2009 | 05:52 PM
eg_boi's Avatar
depending on which LCAs that you have, if u have the stock 92-95 only the USDM and JDM non ITRs will bolt up to the civic LCAs. The USDM and JDM ITR struts go inside the LCAs
Old Aug 5, 2009 | 08:51 PM
s13hero's Avatar
Okay, basically I bought JDM suspension, was told it would bolt to DCs, which should mean it would bolt to EGs, just making sure I didn't need new LCAs
Old Aug 6, 2009 | 03:59 AM
Clerique's Avatar
Just to summarize...
All JDM 92-95 Civics and 94-01 Integras have the same LCA's which is equivalent to the USDM ITR LCAs.
Rear subframes are essentially the same as well, so USDM or JDM LCAs will bolt up to USDM 92-95 Civics.
Damper choice will be based on the above information.
b18c5 power
Oct 2, 2009 08:46 AM
type-GGSR
Dec 22, 2007 11:39 PM
90teg
Aug 25, 2005 07:46 PM
eg_nezay
Jan 7, 2003 06:02 PM
