UT FS!!***900 HP FULL OUT DRAG INTEGRA!!!*** Vid Inside!
Motor is as follows: $5500+shipping!!!! Will Come with everything listed below.
LS block
GE Sleeves w/Orings
CP 84mm pistons with upgrades wrist pins
Manley rods
LS crank
Clevite Bearings
OEM Oil/Water pump
Race Fluidamper (will including removal tool)
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
Fully Ported and Polished by Ryan@Warr heads
GSR Cams
Supertech Springs/Retainers
Supertech Inconel Exhaust valves
Bronze guides
Valve Job
High Amp Alternator
Wiring Harness included
3 Distributors wired for the external coil, 1 LS, 2 GSR's
Custom built Breather kit using 2 Moroso Cans with 4 -12an Lines with return into the block
Valve Cover with 4 -12an fittings welding to it and powder coated Gloss Black
Edelbrock Intake Manifold (intake port matched)
Stock GSR throttle body
Starter
**Mounts/Trans/Scatter Shield NOT Included!**
The Breather kit:
Turbo Kit: $3100+shipping!! (SAVE $300 if ya buy as a kit)
Full-Race T4 Twin Scroll Manifold $1050 shipped!
Dual Tial 44mm Wastegates with .7 bar springs w/dump tubes $700 Shipped!!!
Garrett 4294 Journal Bearing $800 Shipped!
Includes Gasket, Feed/Return lines and fittings.
IC piping Powder coated Gloss black w/42r-S372 connector and Tial 50mm bov flange $300 Shipped!
Kinda goes together how it's layed out!
Will Include the V-Band for turbo Connection
*BOV & Couplers/T bolts clamps not lncluded!
All couplers and T-bolts $110 shipped
Precision 825hp Intercooler $450 Shipped - SOLD!
Tial 50MM BOV (Black) $230 shipped
4" Down Pipe w/flex $300 shipped
VERY well constructed to fit RIGHT up against the slave cylinder and oil pan for a tight
fit to help keep room for traction bar & engine catch pan.
4" Aluminum Exhaust (All With V-Bands) $250 (LOCAL PICKUP ONLY!)
DriveTrain:
Liberty Dog Box transmission with Quaife (GSR ratios, B16 Quaife) $4300 SHIPPED!
Exedy Twin disc Clutch $1050 SHIPPED!
Has Ten Passes on it and approx 200 miles total!
DSS 5.9 Axles w/hubs&knuckles $1300 SHIPPED!
Has the 300m Slug in it with 3 hits and looks great no twisting!
Brakes NOT included! Might consider selling with them for more $$$$.
Avid Traction bars $300 SHIPPED!
IN NEW condition!
Golden Eagle Scatter Shield $165 shipped!
Powder Coated Gloss Black!
Electronics:
S300 with all options $620 Shipped -PENDING
PLX Wideband w/bosch sensor $220 Shipped
AEM 5 Bar map Sensor $75 shipped
AEM Boost solenoid $75 shipped
MSD Digital 7 Plus Prog (#75314 4 cyl apps only) $730 shipped
Will include Serial Cable with IOGear USB adapter cable.
And Wiring Harness if wanted, Shielded Air Craft Wiring was used and need to be grounded.
Shielded wiring reduces electric interference from the box and ECU.
MSD Dig 7 HVC II Coil $160 shipped
IN BRAND NEW CONDITION!
Aeromotive Eliminator Pump $350 shipped
Dual summit filters with 100 michron inserts (before and after the pump) $100 for both
Aeromotive FPR w/Pressure Gauge $140 shipped
Bosch 1600cc injectors $160 shipped - SOLD!
Golden Eagle Fuel Rail $100 shipped
with -10an & -6an fittings
Hasport Solid Mounts Powder coated black $300 shipped - Pending
Del Sol Dual Core Radiator w/slim fan $110 shipped
Full Racing Suit (Shroud Pants, Shroud Jacket, Simpson Shoes, Shroud neck brace, Shroud gloves) $450 shipped
Spinwerks Drag Wheels (slick below included) $600 shipped!
MT 24.5"x9" slicks
About 10 Passes. Wheels look BRAND NEW!!! Slicks have TONS of meat left!
VIS Invader Carbon Fiber Hood $350
1994 Acura Integra GSR Black Chassis: $5500!!! Local pickup only!
10 pt Cage, not cert yet but built for certification to 8.50's
Custom fitted MR Window net
Certified shroud 5 pt Harnesses (both drivers and passenger)
Shroud Parachute
Innes Cutoff Switch
OMNI drags 18K rear, 12K fronts coil overs
OMNI Camber Kit (front)
Powder coated wheel with Toyo Rears, Falkin Front tires
Paypal address is SupraTT_T78@hotmail.com
Jason
801-879-4940.
I do have texting so. Text me if ya got questions.
LS block
GE Sleeves w/Orings
Manley rods
LS crank
Clevite Bearings
OEM Oil/Water pump
LS oil pan Tapped
GE LS/Vtec Kit
GE 84mm head gasket
GSR Head
GSR Cams
Bronze guides
Valve Job
High Amp Alternator
Starter
The Breather kit:
DriveTrain:
IN NEW condition!
Electronics:
MT 24.5"x9" slicks
Shroud Parachute
Innes Cutoff Switch
Jason
801-879-4940.
I have before! haha Kinda scary with the laws and cops around Utah tho... Impound the car for anything and everything. It sucks *****!!!! Cars a BLAST on the street!
