combination of idles
Old Aug 4, 2009 | 03:40 AM
primerpimpin's Avatar
Default combination of idles
92 civic HB
d16y8 block and head
92 zc intake manifold and wire harness
p 28 ecm
Did a small rebuild on the head a few weeks back (head gasket/ intake man. gasket/ valve seals/ everything sand blasted/) Have it all together and now my idle will be stuck at 1200 or surge between 1000 and 100 or it will surge from 1000 to 1500. Its different everytime i come to a stop. And if it does idle at 800 the muffler sounds like its spuddering. And when im in gear but slowing i feel a faint sputter. Also when i put it in neutral just before stopping it will be stuck at 2100 until iv been stopped for about 10 sec. I thought i had air in my coolant so i took off the rad cap let it run but i was continuously getting small bubbles for over 30 mins. I know my FITV is leaking but i blocked the hole inside the throttle body (temporarly) but no help. Could this FITV be the problem to all my headaches. New IACV, No CEL, No clue?????
iv researched and did the troubleshooting but to no prevail.
Old Aug 4, 2009 | 07:30 AM
angel_i's Avatar
Default Re: combination of idles
Sounds like this is the problem especially if it ran fine before.
Old Aug 4, 2009 | 08:10 AM
my concern is would a leaking FITV cause bubbles in my coolant. I know its controlled by the coolant but im scared my head gasket did not seal right or something (even though i had no issue putting it on)
Old Aug 4, 2009 | 08:41 AM
Former User's Avatar
Compression test the cylinders.
Old Aug 4, 2009 | 10:10 AM
ya ill do that this weekend. Did some more driving trying to figure this out. Iv pin pointed when its cold it idle extremely low (100rpm) But once its warm it idles at 1200 or a little high but if i tap the gas it will come down to normal (like its getting stuck at 1200). also thanks for the advice and help!!!
Old Aug 10, 2009 | 12:06 PM
JDM-EyeKandii's Avatar
New User
Check your i-vac valve
Old Aug 10, 2009 | 05:39 PM
i let the car warm completly then felt the lower hole in the throttle body (FITV) and it was sucking air. So that means its leaking so soon ill be changing that and hopfully that will do it. OH ya and about the IACV i had got one from a junkyard then cleaned it and had it tested, plus no cel
Im also getting real bad gas milage and no power. I think the leak is causing the ecm to pumop way to much gas in the engine
onlinmrine
Feb 10, 2022 12:17 PM
mattcod6fan
Jul 17, 2015 10:51 AM
ArtyTheKid
Feb 22, 2013 11:27 AM
crazyboy
Dec 29, 2012 06:46 AM
westside49block
11
Feb 2, 2008 09:32 PM
