Cheap system for '00 Civic coupe?
Old Aug 3, 2009 | 03:13 PM
calvin924597's Avatar
Default Cheap system for '00 Civic coupe?
Right now I just have the stock system, minus one of the front door speakers. So pretty much anything would be better than what I have. I might stick with the stock HU so I can keep keyless entry (unless there's a way to have keyless entry with an aftermarket HU) but I need better speakers, and maybe a cheap amp/sub. What should I do? Thanks
Old Aug 3, 2009 | 09:07 PM
8520's Avatar
Default Re: Cheap system for '00 Civic coupe?
What's your budget?
They make a retention harness for your keyless, but you have to keep the stock radio in the car.
Personally I would get a 96-98 center console, and put an aftermarket radio in the roughly din sized hole. That's what I did on past civics so that everything "looks" stock.
Old Aug 12, 2009 | 02:11 PM
So the hole in there now isn't din sized? :/
I might just stick with the stock deck then and get new speakers. Will I run into any problems trying to do that? I know I need wiring harnesses for each speaker.
Originally Posted by 8520
What's your budget?
Old Aug 12, 2009 | 05:29 PM
98civdx's Avatar
Master Detailer
there is really is no point to put aftermarket speakers in with a stock deck, simply due to the fact the stock deck cant give them the power they need.
as 8520 said there is a way to keep it, just get the harness and slip the stock hu behind the lower dash cover.
the hole in it now is a double din, but the stcok hu is a single, but when you remove it youll see what we mean, just grab a deck instal kit.
are the stock speakers blown?
you dont NEED a harness for the speakers, you can just cut the connector off and crimp on the right connectors for the speakers,
Old Aug 12, 2009 | 06:08 PM
DrAzTiK87's Avatar
I had a 99 Civic EX and swapped the deck out with no problem... keyless entry still worked. Whats the difference from 99 to 00?
Old Aug 12, 2009 | 06:09 PM
98civdx's Avatar
Master Detailer
no difference, they are the same.
Old Aug 12, 2009 | 08:26 PM
DrAzTiK87's Avatar
If you want to keep the stock deck hook up a line converter. Add an amp and change the speakers.
Moms 94
11
Aug 3, 2013 02:16 PM
freezingcoffee
Dec 21, 2005 03:18 AM
tim5371
Aug 22, 2004 08:25 PM
ALF
Audio / Security / Video
Aug 1, 2001 08:03 PM
red97gsr
Apr 19, 2001 08:46 AM
