anyone ever done a h2b swap and still have a/c in their eg6???
Old Aug 3, 2009 | 09:31 AM
mynameizstitch's Avatar
Default anyone ever done a h2b swap and still have a/c in their eg6???
anyone here know if doing an h2b swap you would still be able to keep the a/c or is it not possible? i live in california and it's got hot summers so if ima have to take off my a/c im not goind to even try to attempt this swap. a/c is toooo important for me since it will be my dialy driver.
Old Aug 3, 2009 | 04:12 PM
98civdx's Avatar
Master Detailer
Default Re: anyone ever done a h2b swap and still have a/c in their eg6???
i dont even think it can be done, due to where the pumps are on the h22 and on the civic, also due to the size of the engine.
but i may be wrong.
why not just save your money and do a b sereies, and use all that extra money you would have spent on the h22 on other parts.
Old Aug 3, 2009 | 04:41 PM
Anton LaVey's Avatar
but i may be wrong.
dont listen to this fool anything can be done
Old Aug 3, 2009 | 04:46 PM
jshaw23's Avatar
Save what money, the h22 swap is not expensive at all, at least not for my ek it wasn;t. The most money i spent was replacing things that i didn't want to do later before the engine went. Don't listen to that guy at all. Im sure it can be done, but it won't be easy.
Old Aug 3, 2009 | 04:49 PM
D3vin's Avatar
I'm pretty sure you can keep the a/c. Unless your putting a J30 or a J32 into your Civic, anything can be done. J series would take up the whole engine bay literally.
Old Aug 3, 2009 | 06:02 PM
so no one has actually done it? dont really want to spend tons of money to mod my a/c. reason i want a h22 is because stock they run low 13's already with just bolt ons and with slickes it can be in the mid 12's and thats a pretty much all stock h22 not modded so its pretty reliable.
Old Aug 3, 2009 | 06:14 PM
raidacaipo's Avatar
anything can be done but in particular its going to be hard to put on a/c because there is hardly any room for the crank pulley. When doing an h2b swap it is usually required to get the crank pulley machined off so that it will not hit the firewall. The a/c belt shares the same crank pulley but after its been shaved off where will you put it? Its already running an alternator belt but what if you can shared the crank pulley with the same belt going thru the alternator and the a/c?
Old Aug 3, 2009 | 07:23 PM
98civdx's Avatar
Master Detailer
realy? so where the hell is the pump going to go!?
all the lines? condensor?
the crank pully HAS to shaved down to clear with h2b, so where is the belt going to go!
oh and by the way i never siad it couldnt be done, but it hasnt as far as i know,
Old Aug 3, 2009 | 07:28 PM
slowhatchcali's Avatar
only if there was electric ac pumps! lol that'd be sick
Old Aug 3, 2009 | 07:30 PM
98civdx's Avatar
Master Detailer
^^ id buy one right now!
Old Aug 3, 2009 | 07:42 PM
NastyHabitzCRX's Avatar
doesn't someone sell an AC bracket that allows you to use the sohc compressor??
Old Aug 3, 2009 | 07:47 PM
raidacaipo's Avatar
SOMEONE IS SELLING SOMETHING LIKE THAT?!?!?! I heard of evolution selling the bracket that allows you to use the sohc alternator...
Old Aug 3, 2009 | 08:26 PM
HP made such a bracket, don't know where to get em though. Innovative does make an EK sohc compressor bracket.
Jman7613
Honda Civic (2001 - 2005)
Dec 30, 2016 12:15 AM
acclude23vtec
Oct 31, 2005 04:59 PM
GetawayInMoscow
May 18, 2004 07:03 AM
rkn527
Mar 26, 2003 06:04 PM
